13 F250 Flatbed
Old Jan 11, 2022 | 06:19 AM
Lifeisgood!'s Avatar
Lifeisgood!
13 F250 Flatbed
I'm looking at buying a '13 F250 with a 6.2 with 120k miles. I'll be pulling a trailer anywhere from a 12' to a 18' trailer. I'll be doing mostly highway speed 70-80. Will this truck be able to handle that? How long will it last? What are some common problems?
Old Jan 16, 2022 | 05:54 PM
arnegrant's Avatar
arnegrant
6.2s put out good power
Enclosed trailers pull a little harder at freeway speed than flatbed.
You need to check your weight (gvwr and gcwr) to make sure you've got enough brakes to stop.
200k on gas engines is typical
If you run it, you will work on it - just plan for a little more maintenance if you are running hard
Good luck
Old Jan 18, 2022 | 07:54 AM
Birdhunter1's Avatar
Birdhunter1
Pulling the trailer depends on what is on the trailer, I could pull an 18' trailer at highway speeds with my old 3.0 V6 Ford Ranger if there wasn't much weight on it.
Old Jan 22, 2022 | 12:58 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Need an important distinction added: Whatever the length, are you talking box shaped, flat, boat shaped, etc. ?
Is the load on the trailer going to be box shaped, flat, boat shaped, Lamborghini shaped, pickup shaped, etc. ?
Hills?
The more "yes"es above is the more you'll have a harder time doing what you are talking about.
sandroost
All Things Towing
Nov 23, 2021 07:14 PM
rick2003
Mar 22, 2020 10:06 AM
rick2003
Mar 2, 2020 09:04 AM
senix
Sep 3, 2017 12:32 PM
Bo Schmidtke
Nov 14, 2005 01:28 AM
