Tire Chain Advice
Old Jan 10, 2022 | 04:38 PM
DecodanMcQ's Avatar
DecodanMcQ
Tire Chain Advice
Getting ready (Mid-February) to make a trip to west coast from Missouri. Many areas I travel through require chains or at least that you carry chains.
My question is, I need a recommendation for quality set of chains that will fit 295/65R20 Nitto Terra Grapplers on stock 2022 Platinum F-350 SRW wheels.
thank you.
Old Jan 10, 2022 | 04:54 PM
RidgwaySD's Avatar
RidgwaySD
tirechains.com
Old Jan 10, 2022 | 04:55 PM
6.2caribou's Avatar
6.2caribou
Here are a few to choose from. I've always been satisfied with anything that I bought from Tirechain.com
https://tirechain.com/295-65-20-tire-chains/
Old Jan 10, 2022 | 05:01 PM
RidgwaySD's Avatar
RidgwaySD
I run the round twisted ones.
. These are pretty substantial chains. Square link has better ice grip but is hard on roads and sometimes tires. V-bar is mostly for off highway, very low speeds and expect road damage. Get a pair of the center bungees, very handy.
Old Jan 10, 2022 | 05:40 PM
morehouse7's Avatar
morehouse7
Another good source
https://tirechainsonline.com/
I run V-bars with cam locks on all 4 tires. As Ridgeway stated, V-bars are very aggressive so depending on where you use the chains you may not want to get those.
Old Jan 10, 2022 | 07:18 PM
eberlestock's Avatar
eberlestock
I run chains off road but would never drive on a highway with them!
Old Jan 10, 2022 | 08:21 PM
440 sixpack's Avatar
440 sixpack
Sometimes you run them on the hiway or you park it. even on a 4wd.
Old Jan 10, 2022 | 09:16 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
thank you.
I suggest taking the SOUTHERN ROUTE to the west coast!
Old Jan 10, 2022 | 09:34 PM
White 99's Avatar
White 99
Have you checked the owners manual about chains and 20 inch wheels?
Old Jan 10, 2022 | 10:05 PM
scottz99's Avatar
scottz99
Veteran: Navy
thank you.
Even in Colorado, the chain requirement usually only applies to commercial vehicles. Non commercial vehicles are ok with 4x4, winter tires or chains. In 30 years, I have never run chains on the highway. Maybe just me, but if conditions require chains on the highway, time to take a break. For off-highway, I have had good service from Peerless Chains
Old Jan 10, 2022 | 10:57 PM
Compression-Ignition's Avatar
This style is pretty easy to put on.
But they are not the best type of chain. Realistically I don't think you're looking for a chain that you can run 1000's of miles on. You're just looking for a quick-on get over the pass and pull them off chain. Pretty much anything you find that is the correct size will do that for you. Aside from the super cheap cable crap anyway. Whatever style you buy make sure you test fit them and be damn sure you're not going to tear anything up. Brake lines are pretty important I hear....
Try to hit the passes at around mid day and drive within your capabilities. And before you go have your tires siped. If the tire shops don't do it down there find a dirt racer and he'll hook you up. Terra Grapplers are decent tires, but unless they are brand spankin' new they need a little help to be decent on snow and ice. A bunch of siping will make them stick pretty good. My Terra Grappler G2's were passable the first winter. Next one I tried to get through I had to slice 'em up.
If you've never chained up in a blizzard and don't have tons of practice with this sort of thing, I highly recommend the quick fit type chains. And while I doubt you'll need to use them I seriously suggest you install them at home to see what's what.
ETA:
Where are you headed on the West Coast? I just looked online a few places and chains seems like they are kinda hard to come by right now. If they have Les Schwab Tire stores where you are headed you might try calling them and seeing if they'll ship you some. I just got some quick fit chains from them a month ago as I needed to make a move from Eastern Washington to Western Montana. Had to have the chains just in case. Anyhow Les Schwab will take the chains back if they are unused.
Les Schwab QUICK FIT CHAINS I want to say they were less than a $150 for a pair.
Hanging in the bed of my pickup same size you run 295/65r20.
Old Jan 10, 2022 | 11:23 PM
Tsubakihara's Avatar
Tsubakihara
I have your tire size in Yokohama and got a pair from e-trailer for a little over $100. They were on sale. Been about three weeks or so. Test fit in the driveway and all good.
Old Jan 10, 2022 | 11:52 PM
HRTKD's Avatar
HRTKD
Colorado has two stages of chain law. Stage 1 is fairly easy to meet. Stage 2 requires chains. No quibbling - chains are required.
Here's the CO chain law details: https://www.codot.gov/travel/winter-driving/tractionlaw
If you're not going off-road, get a set of S-Class chains for the front. That's all you'll need for on the highway or around town. I have both S-Class (post #11) and ladder style (post #4). If I'm on pavement, all I'll use is the S-Class on the front tires unless the snow is super deep and I really, really need to be somewhere.
Old Jan 11, 2022 | 10:55 AM
Tsubakihara
I've never had to chain up in my life. With that said, I assumed I would put them on the rear?
Old Jan 11, 2022 | 10:58 AM
Baja Fog's Avatar
Baja Fog
275/65R20
Bought these: https://www.etrailer.com/Tire_Chains...in/TC2335.html
2335 Titan Chain Diamond Alloy Snow Tire Chains - Square Links - Light Trucks - One Pair
These chains fit the following tire sizes:
  • 275/65-20
  • 285/60-20
  • 285/75-17
  • 305/45-22
  • 305/50-20
  • 305/65-17
  • 305/70-16
  • 33x12.5-17
  • 33x13.5-16
  • 35x13.5-16
