1995 7.3
Old Jan 10, 2022 | 10:55 AM
Aaron Barton's Avatar
Aaron Barton
Is there any way to bleed the fuel lines on a 1995 7.3
Old Jan 10, 2022 | 12:19 PM
Ford Firefighter's Avatar
Ford Firefighter
What part of the system are you wanting to bleed? Like from what point to what point? And what for?
Old Jan 10, 2022 | 02:33 PM
Aaron Barton
I don’t know where or what I need to bleed because I removed the fuel line on the regulator and I removed the fuel filter housing completely and changed the fuel pump and ipr, ICP so I don’t know how or where to bleed the fuel system
also the truck won’t run at the moment trying to get it to finally start
Old Jan 10, 2022 | 02:38 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
Crank it until you bleed it. I would add some fresh No 2 to the fuel filter bowl to help prime it faster.
Old Jan 10, 2022 | 02:40 PM
Aaron Barton
I filled the housing with brand new diesel and I’ve still been having no luck and no smoke when cranking just the smell of diesel in the exhaust and air around it
also a list of new parts on the truck:
cps
icp
ipr
fuel pump
Old Jan 10, 2022 | 02:52 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
How much cranking have you performed? Plug it in too, easier for the thing to turn over with hot oil.
Does tach move cranking?
Why did you replace all those parts?
Old Jan 10, 2022 | 04:05 PM
Aaron Barton
The truck has previously been running and then it sputtered and died so that’s why I have been replacing parts trying to find the problem and yes the tach moves while cranking
I have also been cranking on the truck for abt 10 minutes each day for a few weeks
Old Jan 10, 2022 | 04:14 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
Glow system? Battery charge level and cable condition? Weak starter? Bad new sensor(s). Seriously, plug it in for three or four hours
Too many variables with not enough tested.
Old Jan 10, 2022 | 04:23 PM
Aaron Barton
Glow plug system is working brand new batteries fully charged and have a block heater element in j the way to replace the bad one
Old Jan 10, 2022 | 04:29 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
https://drive.google.com/file/d/0Byb...1qRU1VVGc/view
Check that out.
Old Jan 10, 2022 | 07:17 PM
crazy wheel's Avatar
crazy wheel
The first time that I removed my fuel filter housing and reinstalled it, My truck would not start.
I had missed getting a wiring plug reconnected. It might be something as simple as that.
Old Jan 12, 2022 | 03:17 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
You need a scan tool or mechanical gauge plumbed into a high pressure oil rail to determine if you have the required 450 PSI + to allow the PCM to tell the IDM to actuate the injectors. Two of the parts you replaced can easily cause a no-start. Where did you get the ICP and IPR?
Also, removing the housing can disturb the often brittle/deteriorated IPR harness and cause a short between the two wires. This can, at best, just cause the IPR to not function (constantly open allowing bypass back to the sump) or at worst, fry the IPR driver in the PCM resulting in paying for repair or replacement. Hopefully it's not the latter.
markkevin
Maryland Chapter
Aug 2, 2024 06:17 PM
Everlanders
Aug 13, 2018 02:30 PM
ncfirefighter46
North Carolina Chapter
Jul 5, 2008 11:59 PM
swaybar
Apr 6, 2008 07:35 PM
