2021+ F150 Discuss the 2021 Ford F150
Sponsored by: Real Truck
Auto High Beams
Old Jan 10, 2022 | 06:43 AM
ArToolMan's Avatar
ArToolMan
4wd Low
Auto High Beams
I drive my 2021 F-150 XLT three miles down a rural one lane road early each morning to get to the highway. By design, I have to manually turn the high beams on at such low speeds. Once I turn on the highway, and reach highway speeds, the high beams do not revert back to Auto High Beams. To get the Auto High Beams to work I have to switch the headlight switch to the On position, then back to Auto to reengage the Auto High Beam feature.
It seems this should happen automatically. Am I missing something?
Old Jan 10, 2022 | 08:02 AM
RossRR's Avatar
RossRR
After you cycle the column switch for hi / low beam, deactivating auto high beam, switch again to low beam and one more time to reengage auto-high beam.
Old Jan 10, 2022 | 06:05 PM
GABAR's Avatar
GABAR
Just keep it in Auto mode and hit the high beam when needed.
It’ll take a few seconds but the auto high beam system will switch to the auto mode after driving a bit but if it’s not soon enough for you, once you hit the column to turn them off, it’ll be in auto mode and act normally.
Old Jan 10, 2022 | 06:49 PM
ArToolMan's Avatar
ArToolMan
4wd Low
They never have before. I drove 15 miles this morning at highway speeds and they never switched back to Auto. That’s the reason for my post.
Old Jan 11, 2022 | 11:31 AM
ArToolMan's Avatar
ArToolMan
4wd Low
That fixed it. Thanks.
Willfish4
2004 - 2008 F150
Jan 19, 2016 09:14 PM
Graeme
Feb 20, 2009 10:17 PM
metalcaster
Jan 27, 2003 07:48 PM
