10 speed cold weather temps
With the cold weather that recently settled on the Midwest, I noticed a change in how the 10 speed shifts in my 2022 7.3 F250. A quick bit of Googling indicates that other truck owners have noticed this with the 10R140. The specific change is a "bump" when it shifts up from 3rd (either to 4th or 5th). From what I've read, the TC lock up point + higher viscosity fluid causes the bump.
Upon noticing the change, I was curious to see what the tranny temps looked like. After a 10 min warmup in the driveway on a 28 degree morning, the engine was 180 and the tranny was 50 degrees. The transmission did not go above 130 degrees after 20 mins of driving which included 5-6 stops and then acceleration up to 60 mph. I am interested to know what other 10 speed owners are seeing for transmission temps in <30 degree weather.
The following users liked this post:
The following 2 users liked this post by 2021F350:
Started up my truck this morning, -24*C/-11*F.
After 5 minutes of idling the tranys temp was -15*C/+5*F.
After 10 minutes of driving the tranys temp was 0*C/+32*F.
After 20 minutes of driving the tranys temp was +25*C/80*F, and, it finally shifted into 9th & 10th.
After 30 minutes driving the tranys temp was +43*C/116*F, and it didn't get any warmer for the rest of my 40 minute drive...
If my memory serves, in the summer, +25*C/80*F days, the tranys temps were mostly between +89*C/208*F and +98*C/226*F...
One morning last week I started my 7.3 truck which had sat outside all night and the air temp was -30 F. It started right up (dual batteries are awesome). I drove empty for about and hour an half of mixed town and country driving and shifting was normal with maybe just slightly higher revs than normal. Trans temp never got above 125.
Seems to shift like it was in TH mode this morning, until it warmed up to +25*C/80*F... I went for another drive this afternoon, and the trany started out at +23*C/+76*F and it basically drove like it always does in normal mode & at the end of my drive it was up to +54*C/+129*F...
It is a substantial change in gearing when shifting from 1st to 3rd. When the elevated cold start idle is enabled, you are going to get a "lurch" on the shift. No way around it. As the motor and tranny warm, this effect is greatly reduced. That said, I do think the 10 speed shifts smoother after it is thoroughly warmed. My 10 speed is normally 190 to 205 in the summer. Now that it is often zero or less, the tranny is often in the 90 to 130 range.
Was -27 this morning was plugged in so drove 2 mins after starting up 2022 6.7, tranny was / has been sluggish for sure and would not come out of 9th until 70mph as was on highway 5 mins after startup, after 10-15 mins all was good. In this cold weather though engine takes 20-30 min on highway to reach full running temp. Bigger issue I’ve had is the drivers side floor vent is weak have to move feet to find the warm air.
https://www.ford-trucks.com/forums/1...loor-heat.html
