Ford 9 inch rear
Old Nov 5, 2003 | 02:15 AM
godavesec's Avatar
godavesec
Ford 9 inch rear
I am in the process of having a 9 inch rear axle modified to my specs. An issue that came up is the offset pinion yoke. I will be putting the new rear axle in a car that formerly had equal length axles. Don't I have to specify unequal axles lengths, so the new pinion yoke will be centered? If so, how do you calculate this...is there a "standard" offset I can refer to? Thanks.
Dave
Old Nov 5, 2003 | 09:18 PM
rebocardo's Avatar
rebocardo
Very few Ford 9 inchers had unequal axle lengths, except maybe a Lincoln or two.
