I just bought a F150, SC, 4x4, without an owner's manual. It seems like a nice truck. Is there a site I can punch in the VIN number and get info on the truck, such as rear-end ratio, limited slip, etc.?
Not sure about a sight, everything you need to know should be on the truck. For instance, there should be a tag on the rearend that has the gear ratio on it. If it is a limited slip it should have a 3L55 or if not just a 3 55, that is most likely what gears you have though. As far as other stuff should all be contained on the door sticker or on the cowl tag. Let me know if I helped at all, or if I can be of any further assistance.
The 3.55 would have a door code of 19 the 3.55 limited slip would have a code of H9.
***********PASTMASTER***************
1993 XLT 5.0 E40d 3.55LS Normal Cab/Long bed Loaded from the factory with aid of...MSd 6a ign/s.p. wires, blaster coil, Hypertech Chip, K&N filtercharger, Cat-back dual exhuast w/o mufflers, 3.5", echo tips, Accel distributor cap, Dark Mocha over light mocha. 5% Dark tint, Alpine Cd player/remote, Pioneer speakers.
