Removing the windshield wipers
Old Nov 5, 2003 | 12:20 AM
GeneStoner's Avatar
GeneStoner
I'm fix'in to paint the truck and need to remove the windshield wiper arms. How is this done?
Old Nov 5, 2003 | 12:36 AM
BigBully's Avatar
BigBully
Just pry them up from the short side. There is a little spring that holds them down
Old Nov 5, 2003 | 12:38 AM
BigBully's Avatar
BigBully
And its a little easier if you lift the blade off of the windshield and put a wire or small allen wrench through the holes in the arm right next to the shaft. It will hold the pressure off whlie you remove them
Old Nov 5, 2003 | 09:19 AM
beartracks's Avatar
beartracks
I seem to remember a little lever underneath the mounting area you have to pull up on. They tend to stick after years of sitting there.
