Sponsored by: Real Truck
Been chasing this for months
Old Dec 31, 2021 | 02:52 PM
7pointtree's Avatar
7pointtree
I've got a 2000 F250 7.3 with 308k miles. I have this annoying surging with light but steady throttle from 10mph-60mph. Once as high way speeds it goes away. It doesn't always happen either. Some days there's no surging other says it's all the time under 60mph.
In the last few years I've replaced the following:
InjectorsIPRICPCPSBatteriesFuel bowl o-ringsFuel linesHigh pressure oil linesFuel filter every other oil changeCharge pipe bootsDown pipe and exhaust.
I've also been running a "street" tune off of the SCT X4 tuner. I recently removed it as I thought it might be a fueling issues..
Old Jan 1, 2022 | 10:45 AM
Brother Les's Avatar
Brother Les
Have you ever cleaned out your Exhaust Back Pressure Sensor and Tube?
Welcome to guzzle's Exhaust Backpressure Sensor Cleaning Maintenance Web Page
Also look at you ICP (Injector Control Pressure sensor. Is there oil leaking out of the connection? Change it. Unplug the ICP, does the truck run better? Test drive unplugged?
There is a 1999- 2003 7.3 Diesel section, post there for more suggestions.
Old Jan 1, 2022 | 11:50 AM
7pointtree's Avatar
7pointtree
I have not I'll give that a go. I replaced the ICP back in August but I'll give it another look. Ive only used motorcraft replacements as I've heard these truck need those compared to other brands.
​​​​​​Thank you 👍
Old Jan 17, 2022 | 07:47 AM
SDSC4X4's Avatar
SDSC4X4
Just saw this post. My experience might be a longshot for you, but here goes:
My '01 (gas V10) came from the factory with a very slight surge at exactly 70 mph. My dealer contacted Ford for assistance as they had no information/experience with the problem. They were told the ABS module was not communicating with the PCM correctly and to replace the ABS module. When they did the surge went away.
robert_l_ross
Oct 13, 2014 12:29 PM
rlozer
25
Jul 31, 2014 06:00 PM
dvskate
6.4L Power Stroke Diesel
Feb 16, 2013 02:57 PM
galenfz6
Jun 19, 2012 07:58 PM
JohnnyMack
Aug 18, 2002 02:01 PM
