351W Ford reman engine- tips??
Old Nov 4, 2003 | 06:32 PM
Buzzard_Wing's Avatar
Buzzard_Wing
I just left my 95 F250 with the dealer (first time since I have owned it!) because it has a knock (bearings?) and is using oil like I am some kind of shiek.
It is likely they will recommend a Ford remanufactured long block.
Anyone have any experience with a 351w 'factory' reman, or any tips??
Thanks
Old Nov 4, 2003 | 07:10 PM
90f150moneypit's Avatar
90f150moneypit
Ford doesn't rebuild the motor's themselves, authorized shops do. But they do use genuine Ford parts and have a decent warranty.
It should be just fine. :-)
Old Nov 5, 2003 | 10:54 PM
Buzzard_Wing
Dealer said some of the noise is the AIR pump (not bearings) and there are a couple of minor leaks (none on the driveway?!) Likely rings.
Since this truck was a fed. govt. truck (auction deal) I would expect that it could have idled for a couple of months somewhere along the line.... part of the deal is figuring that this kind of problem could crop up. I have put more than 25k on it in less than a year.
