Corbeau seats - 97 bench
Old Dec 20, 2021 | 02:46 AM
hokievet's Avatar
hokievet
Anyone running corbeau aftermarket seats and using their model specific brackets
I have a extended cab 97 bench seat and wanting to go captains and a console.
thanks in advance
Old Dec 20, 2021 | 05:53 AM
GNR22's Avatar
GNR22
I have a set of Corbeau baja suspension seats in my '94 F350, with a factory bronco console between the seats. No issues with fit. One gripe that I do have, which is definitely my fault, is that the seats suck to get in and out of because the truck is so tall. The seats have nice side bolsters around your hips, but this also makes it a bear to get over and jump out of the truck. It holds you in nicely once you're in, but I would have already pulled these out if this was a daily driver. I'll have to see if I can find a picture later.
Old Dec 20, 2021 | 07:48 AM
hokievet's Avatar
hokievet
did you use their brackets or fab your own?
Old Dec 20, 2021 | 09:13 AM
GNR22's Avatar
GNR22
I used their bracket. This is in a regular cab truck that had a bench, so I'm not sure if their bracket for an extended cab is dissimilar in design. The bracket for the bench seat replacement uses the existing 4 outer bolt holes in the floor and just has tubing that spans the width of the cab that the seats bolt to. I mounted the center console on top of these bars with self tapping screws.
Old Dec 20, 2021 | 09:49 AM
hokievet's Avatar
hokievet
can you provide a link or a part number to the bracket you used?
Old Dec 20, 2021 | 01:29 PM
GNR22's Avatar
GNR22
https://corbeau.com/ford-f100-f350-o...-seat-bracket/
That's what I used. Fit perfect.
https://corbeau.com/ford-f150-ext-ca...seat-brackets/
The above link is likely what you need.
Old Dec 20, 2021 | 01:37 PM
hokievet's Avatar
hokievet
Which console and which seats did you go with?
I know you said you will post pics later
Old Dec 21, 2021 | 09:48 AM
GNR22's Avatar
GNR22
As promised, pictures below.
The console is the factory center console from an '89 Bronco. The seats are Corbeau Baja RS Reclining Suspension Seats, in black vinyl/cloth. https://corbeau.com/baja-rs/ As I said before, I would not get these if this is something you frequently get in and out of, but they are fine for my use as a competition truck. They are very comfortable when you're in the seat, and the suspension part is almost a necessity as the truck doesn't exactly have a great deal of suspension movement, but egress/ingress are not great. If I were to get a different set, I'd probably get the Moab reclining seats, as the side bolsters on the seat bottom aren't nearly as high.
Klondiker
Apr 25, 2017 08:48 PM
Iversen-fords
Sep 22, 2010 06:55 PM
General Davis
New York Chapter
Oct 3, 2005 06:58 PM
