2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Turn Signal Lights!
Old 12-18-2021, 05:00 PM
WykidF350's Avatar
WykidF350
WykidF350 is offline
Turn Signal Lights!
I have a 2022 F350 XLT with blind spot & cross traffic warning. I’m looking to replace the turn signals front & rear. I will be going with the GTR Lighting 2.0’s. Switch backs in the front and amber rears. What’s the bulb size for them?
Thanks
Old 12-18-2021, 05:40 PM
BC2019F250's Avatar
BC2019F250
BC2019F250 is offline
I don't have the answer but your owners manual should.
The following users liked this post:
Old 12-18-2021, 07:21 PM
WykidF350's Avatar
WykidF350
Didn’t think about looking there, thanks.
Old 12-20-2021, 09:44 AM
Great Danes's Avatar
Great Danes
Great Danes is offline
I would strongly suggest you pull the existing bulbs and physically check them. On my truck the manual was different from what was actually in the housing.
The following 2 users liked this post by Great Danes:
Old 12-20-2021, 12:42 PM
Poncho450's Avatar
Poncho450
Poncho450 is offline
I have GTR switchbacks in my 2020. https://www.gtrlighting.com/gtr-ligh...443?quantity=1 OR https://www.gtrlighting.com/gtr-ligh...443?quantity=1
Another good source: https://www.f150leds.com/collections...250-super-duty
GTR has pulldown menus to use to determine which bulb for your model.
Here's a list of what I used in other spots on the truck for LED replacement:
But contact whichever vendor you choose to verify fitment.
Old 12-22-2021, 11:12 AM
Poncho450's Avatar
Poncho450
OK, I pulled the switchbacks out of my 2020 yesterday before I took it in to trade. GTR Armor series, number 4257. Great bulbs that snap in very securely. I had other brands in the past that I had to wrap with electrical tape to secure. Not so with GTR.
Old 12-22-2021, 01:43 PM
Rick Cargo's Avatar
Rick Cargo
Rick Cargo is offline
When installing the GTR bulbs do you also have to install a inline resistor so that your turn signals don't blink really fast?
Old 12-22-2021, 03:09 PM
WykidF350's Avatar
WykidF350
Not if you use the GTR Carbide 2.0. You also can use ForScan to stop the fast blink
Thanks for the tip on looking in the owners manual. Found out the bulb type and called Headlight Revaluation to cross reference the bulb and came up with 7443 single filament for the rear and dual for the front. As said, I’ll be running switch backs in the front. Also, CK Type bulbs need to be used in the turn signals only and non-CK in others. I’ll post pics and a vid of the lights!
Thanks
Parker Jensen
11-20-2020 10:33 AM
randydandy
08-04-2018 12:41 AM
flyvee1
Electrical Systems/Wiring
04-13-2003 01:13 PM
Quick Reply: Turn Signal Lights!
