I Need some help
Old Dec 16, 2021 | 07:13 PM
Lionheart36's Avatar
Lionheart36
I Need some help
I have a 89 f159 302 Larriott. I blew a lifter so replaced the lifters and put a new cam in. Hook everything back up and the engine turns extremely slow. Was checking the timing and now the engine only clicks when I try to start it… put a new starter, starter solenoid and battery in. Does anyone have any tips or ideas about what’s going on and how to fix it?
Old Dec 16, 2021 | 07:45 PM
85e150's Avatar
85e150
Welcome to FTE.
So the engine is slow turning over and has not started?
Is the cam timed correctly?
Will it spin if you pull the spark plugs?
Is the new cam properly lubed with assembly lube, high zinc additive in the oil etc?
How did you set ignition timing to start?
Old Dec 16, 2021 | 09:19 PM
Prototypemech's Avatar
Prototypemech
Does it 'click' once or multiple times? That would be an indication if its bad connection or a bad battery/stalled starter.
Old Dec 19, 2021 | 04:03 PM
Lionheart36
it clicks once when I try to start it. I messed with the timing earlier and it cranked over as it should but it started clicking again. I moved a ground to make sure it was properly done and it still only clicks.
Old Dec 20, 2021 | 04:44 PM
Prototypemech
That's good. That just means you have a loose connection somewhere or a bad component. Your battery and engine are fine, you're just not getting enough juice to the starter to turn it over. What condition are your positive starter cable in? Did you happen to make your own battery cable? That would be the first place I look. If you wanna get technical, you could use a Voltmeter and connect one side to the positive battery post, and the other end on the start positive lug. Try to crank the engine and see what value appears on the Voltmeter. It should be less than a 3v. More than 3v indicates a component with high resistance.
If you don't wanna get technical, hold the key in the start position for about 5 seconds, then quickly put your hands on the battery cable, starter relay, starter, and all the cables in between. If you find one that's hot, that's the component that has high resistance and needs to be replaced.
Old Dec 20, 2021 | 04:54 PM
rla2005's Avatar
rla2005
Which ground did you move?
If it was anything other than the main ground between the battery and engine block you wasted your time.
Old Dec 20, 2021 | 04:55 PM
OhioFordFarm's Avatar
OhioFordFarm
turn on the the light inside the cab, try to start it. Does the light DIM or go out when trying to crank the motor over?
72rtchallenger
21
Nov 2, 2020 01:37 PM
Stonesetter1
May 29, 2015 02:31 PM
Javier89F150
Apr 8, 2015 02:00 PM
StrongRepublican
22
Feb 19, 2007 02:20 PM
Daddywags
Jul 23, 2003 05:13 PM
