My 1977 F-250 highboy restoration
#76
The following users liked this post:
#77
#78
I haven't posted anything in awhile, the wife wanted the main bathroom updated so not a lot of progress. I think I got the wiring figured out, being 46 years old and several owners it's had plenty of repairs. I still need to brake the camshaft in, which will be done at my buddy's shop. That process will be done on the Superflow dyno, and may as well make a couple of pulls to see where the horsepower and torque are. Once that is done then I can finally marry the transmission and start bolting some sheetmetal on.
The following 6 users liked this post by BHoffa:
#80
#82
I got the engine on and off the dyno in one piece. I was a little nervous with the break in procedure but everything went smoothly. The best dyno pull was 424 HP @ 5200 and 518 FT LBS @ 3700. I was hoping for 400 HP.
I used Eastwoods cast aluminum for the transmission. I was surprised at how nice it went on and nice it looks.
It's getting there, front dress and radiator core support next.
The following 2 users liked this post by BHoffa:
#83
#84
#85
Thank you.
The dyno runs were not with the L&L's, we used a set of Hooker super comps. I had my headers coated to make them last a little bit longer being that they are mild steel. Usually when you run coated headers on the dyno they get discolored or "burnt" looking.
I'm 100% sure the engine would make less power with the L&L's, who knows maybe my 400 HP isn't that far off?
#86
#87
I hope these photos and part numbers help a fellow enthusiasts doing a similar build.
The carb is standard Holley 3310, but I wanted something different and kind of "Fordish" so I found on eBay this "cobra clone" crossover kit with rear metering block.
I used the Ford Racing M-6675-A460 oil pan kit, the only unfortunate problem was with the dipstick. I had to do a little rebending for header clearance and make a new bracket.
I purchased the Benchworks Steering conversion kit for a highboy.
I Knew I had to modify the radiator core support and fan shroud for steering box clearance. It wasn't too bad to do, just time consuming. The radiator is listed as "HD cooling w/AC" and the fan shroud (D7TZ-8146-D) is listed as "Super Cooling".
#88
#89
#90
Curated Content Editor
General Automotive Discussion
11-03-2017 02:21 PM
Country705
16
05-12-2009 09:00 AM
