Centramatic question
Old Dec 29, 2021 | 08:22 PM
cwtex04's Avatar
cwtex04
I installed the Centramatic’s today on my truck and they seem to take out the small vibration I had .
Old Dec 29, 2021 | 10:31 PM
scottz99's Avatar
scottz99
Veteran: Navy
Originally Posted by cwtex04
I picked up my Centramatic’s today , turns out I’m only about 30 miles from them. They did say if my tires were new it’s best to leave factory weights on for the first 10k after that it doesn’t matter either way .
Did they say why to leave weights on for 10k?
Old Dec 29, 2021 | 11:02 PM
cwtex04's Avatar
cwtex04
I didn’t ask since I’m at 35k on my tires . Maybe breakin on the tires ? I’m not sure . I did ask if I should takes weights off and they said leave them on or take them off it didn’t matter. Since I just rotated and balanced tire I left them on .
Old Dec 30, 2021 | 02:01 AM
Adam R's Avatar
Adam R
Strongly considering getting a set of centramatics, if for nothing else so I no longer have to deal with or watch the tire monkey's at Discount like a hawk. Did anyone else do it for that reason?
Old Dec 30, 2021 | 07:50 AM
pig9r's Avatar
pig9r
I have read that they make sound at lower speeds. How noticeable is it?
Old Dec 30, 2021 | 07:55 AM
fleming23's Avatar
fleming23
Until you reach about 25-30 mph, it sounds like a small air leak in a tire (a whooshing sound), but mostly only noticeable if your windows are down. I don't think I could honestly hear it with the windows up.
Old Dec 30, 2021 | 09:01 AM
cwtex04's Avatar
cwtex04
Discount won’t touch the tires on a 450 so I’ve been using the dealership. Checked a truck tire place but they wanted more than the dealership for the same service.
Old Dec 30, 2021 | 09:02 AM
cwtex04's Avatar
cwtex04
Its not bad , you can hear it at low speed with windows down.
Old Dec 30, 2021 | 12:50 PM
scottz99's Avatar
scottz99
Veteran: Navy
That is the main reason for me. Plus getting a continuously updated balance job.
After one of the national chains screwed up my wheels and hub caps, I took it to the dealership; they would not work on it either. They sent me to a truck tire shop.
This is what it looked like when the first guys were done.
Old Dec 31, 2021 | 02:45 PM
porthole's Avatar
porthole
After the dealer did similar damage the first time I took my 2011 in for wheel corrosion I always took the caps off myself.
Old Dec 31, 2021 | 05:24 PM
helifixer's Avatar
helifixer
I have them on my '97 F250 and have never heard them and no one has ever commented about a noise.
I am still on the fence with my F450 as my '97 has a tire shake intermittently.
Old Jan 1, 2022 | 11:38 AM
porthole's Avatar
porthole
I have Balance Masters. Similar product but with mercury instead of steel ***** and black powder coated from the factory.
No noise and Balance Masters say to remove the weights.
Old Sep 28, 2023 | 02:15 PM
  #28
Kris Reece's Avatar
Kris Reece
1st Gear
Hub caps
I just installed my centramatics on my 450. The caps on the drw's can be a booger to get off especially if you have a flat on the road. Simple solution, $29 cheapo slide hammer from Harbor Freight using the hook attachment that comes with it. No one will ever have to pry against the shine on your center caps again! And you will not be stranded on the side of the road unable to change the tire because you can't the cap off.
Old Sep 28, 2023 | 05:30 PM
  #29
JS450KR's Avatar
JS450KR
Just installed a new set of front tires on my 450,(Michelin Agilis) no weights, just Centramatics on my way to Florida from Ma.,so far they feel great without any weights.Maybe the brand name of the tire (quality] size and type make a difference, I stuck with stock size.
Old Sep 28, 2023 | 09:41 PM
  #30
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Most likely, the constellation of all the things you did individually contributed to the final effect. You did everything right, and were rewarded with good results.
In the 19.5" tire size, the Michelin "Agiliss" is essentially a rebranded Michelin XZE, which is a steer / all position RIB tire (rather than a tread blocky type tire). That alone makes a huge difference, as opposed to the HD3 tire that came stock on the F-450 pickup.
The standard tire that Ford fits to the F-450/550 chassis cabs is the HS3 (as opposed to the HD3). The HS3 is more like the Michelin XZE (now "Agillis"). So the type of tire, more than the brand of tire (when comparing top tier tire brands) emerges in my mind as larger contributor to a smooth ride.
But it isn't the only contributor. Sticking with the stock tire size reduces weight and mass of the tire. The more material involved in making the tire, the more potential for variances calling for counter balancing.
