Modular V10 (6.8l)
Failed spark plug insert removal
Old Dec 15, 2021 | 07:46 PM
galaxieman390's Avatar
galaxieman390
Hi guys. I just bought a 2001 F250 with the 6.8.
I changed spark plugs and the 4th. Plug back on passenger side would not tighten up. I used a borescope to inspect the hole and discovered it along with the other 9 have inserts already installed. All the other plugs torqued properly and looked fine except this one. The insert seat appears cracked in three places and the insert threads appear to be stripped. How can I remove an already installed steel insert? Could it possibly be drilled out an another time sert or cal-van sert be installed?
Old Dec 15, 2021 | 10:12 PM
Bently_Coop's Avatar
Bently_Coop
Not totally sure, however I do believe a over sized insert from Timesert or Calvan is available.
Old Dec 16, 2021 | 07:16 AM
JWA's Avatar
JWA
Any idea which brand of insert was originally used?
Old Dec 16, 2021 | 10:26 AM
projectSHO89's Avatar
projectSHO89
Gotta get the old one out first...
If it's an aluminum insert, you can likely drill it out. If it's steel, you'll probably have to use a suitable bolt extractor to unscrew it. Lot depends on what it actually is...
Got any borescope photos of the failed insert?
Old Dec 16, 2021 | 10:27 AM
projectSHO89
Gotta get the old one out first... then see what size the hole is.
Old Dec 16, 2021 | 06:22 PM
galaxieman390
Here is the insert in question.
Old Dec 16, 2021 | 06:25 PM
galaxieman390
I tried a sprial extractor and it gripped at first then just started spinning. Does anyone have a link to a better extractor? Also how hard is it to take the passenger side head off?
Old Dec 17, 2021 | 04:46 AM
JWA's Avatar
JWA
Wow that's one ugly insert.
Removing the head might be your only option at this point sad to say. Do keep in mind I'm not familiar with removing an already installed insert so someone here might have a better idea.
Old Dec 18, 2021 | 08:48 AM
bajaphile's Avatar
bajaphile
I am curious if getting a quality kit like the Calvan would still work in this situation. The clearance hole drill might knock out all that material anyway since the Calvan inserts are so thick.
Edit, even on the Amazon page it says:
  • High quality oversized steel alloy insert will repair other inserts that fail and has no ill effects from heat transfer
Amazon Amazon
Old Dec 18, 2021 | 11:55 AM
projectSHO89
I have no doubt that either the CalVan or TimeSert options will repair the hole once the existing insert is out. That's the hard part.
Old Dec 18, 2021 | 12:15 PM
galaxieman390
Do you think it could be just drilled out with the bit that comes with either the Cal-van or Timesert kit?
Old Dec 18, 2021 | 02:44 PM
bajaphile's Avatar
bajaphile
Found this site which offers a bit of info... I am uncertain how you would measure the insert in the spark plug hole, my calipers wouldn't fit
https://www.wiseautotools.com/blog/f...ow-out-solved/
Time Sert 5553Repairs spark plug holes smaller than .663″ (16.8mm).
Time Sert 5600 – Stand Alone Kit that repairs spark plug holes larger than .663″ (16.8mm).
Calvan 38900Repairs spark plug holes up to approximately .678″ (17.24mm).
There are plenty of extraction tools out there, and I have had decent success with them. In my experience though, its usually smaller diameter fasteners. You might want to try a specific extraction tool made for the spark plug hole size and thread. If that doesn't work, I think drilling out the old one will be the next best option. With the borescope you'll be able to check you get all the chips out at least. That would be my main concern. Doing all this should be a little less work than dealing with pulling the head!
Old Dec 19, 2021 | 06:11 AM
JWA's Avatar
JWA
Cut to the chase and contact CalVan or Timesert for their advice.
Old Dec 20, 2021 | 04:51 AM
tiffy2000's Avatar
tiffy2000
perhaps a big enough left hand drill bit will spin it out
Old Dec 20, 2021 | 05:21 AM
galaxieman390
I sent both cal-van and Timesert an email several days ago and have not received a response yet.
