FE vs FT rocker arm assembly
Sorry if this seems very basic, new to this. I am looking to replace my stock 352 rocker arm assy with a new one, all of the ones I really see say they are for the FE 352, not the FT 352. I understand there are some differences between the two but does this make a difference when it comes to this part? This is the non-adjustable set. 1966 Ford F100...
Welcome to FTE.
There is no such thing as a "FT 352".
FT engines were in medium trucks, not pickups.
So the ones you are finding should work.
Be sure you note the bolts holding the rockers on are of two types and must be put back in the same hole. You'll see one is made to allow oil to pass to supply the rockers.
Having said that, I think the FT and FE use the same rocker shaft, best as I can find.
Just curious to know- what's making you replace your rockers? Parts failure? Upgrading? Poor performance?
Levergun
26
02-10-2007 06:09 PM
