01 Ranger Tranny Problems
Old Nov 4, 2003 | 03:54 PM
Pilar76's Avatar
Pilar76
I have a 2001 Ranger Edge Extended Cab 4x4 with 245CID V6. I have repeatedly taken this in for transmission problems since I have owned it. The tranny shifts very hard and on upshifts from 3-4 and 4-5 around 2300 RPMS, it shudders. Ford has repeated told me that this is normal. So far, I have had the drive shaft replaced twice under TSBs, and have also lubed the slip yoke to eliminate the thud when initially starting down the highway. In addition, the PCM had to be reprogrammed becuase it was originally set at the factory for 15" tires instead of 16". What suggestions do you have
