high idle how-to?
Old Dec 13, 2021 | 10:09 AM
chadstickpoindexter's Avatar
chadstickpoindexter
I wired in a 20k resistor like in the video a few post up. Note that some of the wires were the same colors so I had to figure out which one he was talking about… it wasn’t hard though, I just counted the pins to make sure I had the right one.
Mine is a 22 XLT and the bit above about oil temp being high enough first isn’t true, at least in my experience so far. For example. It was 28 degrees when I got up this morning. I did have the trucks engine block heater plugged in, but I also leave upfitter #2 on and the parking brake set from the night before. Then, when I use my key fob to crank the truck, it will automatically go to high idle. I have done this with the engine block heater plugged in and not plugged in, however high 20’s has been the lowest temps we have had so far. I can’t say that it would still go to high idle in say 0 degree weather, but so far the oil temp hasn’t made a difference.
B-ManFX4's Avatar
B-ManFX4
Originally Posted by zeroo
does that potentiometer have an open position or is it always in resistance?
The potentiometer does not have an infinite (open) resistance spot. It does have a zero resistance spot. That is why I added the 642 Ω resistor in series with the wiper terminal. At worst case the idle will go to 3,000 RPM. However, I wired mine so that the circuit is "seeing" the full 50,000 Ω resistance of the potentiometer when you first enable it. As you rotate the **** the resistance drops, eventually to 0 Ω - but the series resistor I inserted prevents it from dropping below 642 Ω.
Also, the integrated switch on the potentiometer is what applies power to enable the whole circuit. When the **** is first turned, the switch applies power to the circuit and it "sees" the 50,642 Ω resistance of the circuit. I can tell you from experience that nothing happens at this setting. Once I start rotating the **** the idle begins to climb, up to the 3,000 RPM limit.
Old Dec 13, 2021 | 10:16 AM
75Mike's Avatar
75Mike
From 12 volt solutions website:
All of the following conditions must be met for the High Idle Kit to operate properly
  • Engine coolant temp must be above 20 degrees F
  • Transmission temp must be above 20 degrees F
  • Engine must be at stable RPM speed
  • Vehicle speed is zero
  • Vehicle must be in park or neutral
  • Foot off gas pedal
  • Foot off brake pedal
  • Parking brake must be engaged
Any of the following will disable/cancel the High Idle operation
  • Engine temp exceeds 234 degrees F
  • Transmission temp exceeds 240 degrees F
  • Gas pedal is pressed
  • Brake pedal is pressed
  • Parking brake is disengaged
  • Vehicle is taken out of park or neutral
  • Certain engine trouble codes are present
Old Dec 13, 2021 | 10:43 AM
B-ManFX4's Avatar
B-ManFX4
If you want to use a fixed value resistor and not tie up one of the upfitter switches you can wire it this way. You just need to provide a switch somewhere within easy reach.
Old Dec 13, 2021 | 11:02 AM
B-ManFX4's Avatar
B-ManFX4
Here's the same setup with a Parking Brake bypass circuit included.
Old Nov 9, 2022 | 07:45 AM
red9130's Avatar
red9130
1st Gear
I'm getting ready to order the parts from Mouser from your previous reply. Would you mind providing part numbers for this schematic?
Old Nov 9, 2022 | 11:22 AM
B-ManFX4's Avatar
B-ManFX4
MF1/4DC6420F - 642Ω Resistor
https://www.mouser.com/ProductDetail...zo02hK9A%3D%3D
Davies ***** & Dials
https://www.mouser.com/c/electromech...ials/?q=1900-H
CTS Potentiometers
https://www.mouser.com/ProductDetail...VgaIwN4Q%3D%3D
Old Dec 14, 2022 | 08:51 PM
cnote72's Avatar
cnote72
So, if I have the 7.3L gas engine and want to do this to get around 1,200 RPMs, I need a 12086 ohm resistor wired to PTO bundle 9(green) and 10(white/brown), since I have gas, I run 18(yellow/green) to a pass through wire on the inside of truck, find same pass through wire under hood, and finally connect pass through wire to upfitter #1(for me). Is this all correct? I have never had upfitter switches to play with, so need to start making some mods. This is a great site and very helpful, also very costly with me wanting to do all these mods to my new Super Duty.
Old Dec 14, 2022 | 09:50 PM
4wd6.7L's Avatar
4wd6.7L
I haven't wired it up on a 7.3l, but the schematic below doesn't seem to match what is shown above. I'm seeing 9 and 18 having the resistor between, and 7 to the upfitter switch. Also looks like a 10k ohm resistor would give close to 1200 rpm.
Maybe someone else can verify or correct me if I'm wrong.
Old Dec 15, 2022 | 07:40 AM
B-ManFX4's Avatar
B-ManFX4
You are correct - I don't know how I screwed that gas engine part up. I went back and corrected the drawing in the post and added that it is for MY 2017 - 2019 trucks. The resistor values have changed between the 2017 - 2019 and the newer models.
Old Dec 15, 2022 | 11:09 AM
longhaultransport's Avatar
longhaultransport
I'm not judging anyone who bought one, I simply stated the truth - it is overpriced. I don't judge how people spend their money - it's their money. I just stated a fact - that BD "kit" is over-priced. There are less than $8 worth of components that it is comprised of and less than 10 minutes of labor to assemble it. Scroll up in this same thread - I posted the parts and schematics to create one yourself - and it is powered right from the SEIC connector itself - no under hood wiring involved at all.
Would you consider making these harnesses and selling them at a reasonable price?
Old Dec 15, 2022 | 05:12 PM
cnote72's Avatar
cnote72
Thanks for the help and clarification guys. Now I just need to get 1-10Kohm resistor and not 100.
Old Dec 17, 2022 | 09:01 PM
  #28
cnote72's Avatar
cnote72
Never mind, went back and reread thread
nico963
6.7L Power Stroke Diesel
Jun 11, 2021 12:33 PM
jp1096
Sep 29, 2014 07:03 PM
Midnight Ride
Jun 15, 2013 06:05 AM
davbeisner
Dec 28, 2012 10:26 PM
kenny_barg
Mar 20, 2007 10:52 PM
