Glow Plugs
Old Dec 12, 2021 | 05:26 PM
jbevly's Avatar
jbevly
Glow Plugs
I’m researching and all I have dine so far is check the relay and #22 fuse which are both good. What’s next?
i will say the WTS light comes in for about 3 seconds then turns off every time ni matter if it’s cold or hot outside. It was 65 today and wouldn’t start without either. Ince running it’s fine. I’m slowly checking this and that tinkering on it. It’s my dads old truck and just needs some TLC. Thanks for any help.
Old Dec 12, 2021 | 05:52 PM
Edgethis's Avatar
Edgethis
If the relay is good then the next step is checking the actual glow plugs. If you don't have any knowledge of when they were ever done, might as well swap them out. Not a difficult task, not too expensive for motorcraft plugs.
The wiring to the plugs is also worth checking.
Old Dec 12, 2021 | 06:08 PM
Jimmy's Pilot Service's Avatar
Veteran: Navy
Just wanted to make sure you understood the WTS light...
That has nothing to do with the glow plugs on our trucks, it is the PCM running and ready light if you want to think about it like that...
The Glow Plugs run based on oil temp and will be on up to about 120 seconds. The Relay is the middle component for the high current but the signal originates elsewhere.
Old Dec 13, 2021 | 08:19 AM
farmert's Avatar
farmert
Is your truck a Powerstroke, or an IDI? If you have a couple of bad glow plugs on an IDI, it will cause a short cycle of the glow plugs. This sounds to me like what is happening. On a Powerstroke, the computer times the glow plug cycle, so you could have only 1 working plug, and still get the full cycle.
Old Dec 13, 2021 | 08:34 AM
oldbird1965's Avatar
oldbird1965
Disable the glow plugs if using ether.
Old Dec 13, 2021 | 12:17 PM
Hit Man X's Avatar
Hit Man X
Mine starts at 65F with glow circuit disconnected. Grouchy, but starts. Sounds like you may have slow cranking woes compounded with other issues.
There is a thread on here with 'Cranky' in title. Look for it.
BullRidnRenegade
18
Feb 16, 2012 06:28 AM
TURBO-J630
Sep 28, 2011 09:51 AM
taandctran
May 13, 2010 12:15 PM
jcab
Dec 31, 2007 06:24 PM
Ed in Maine
May 25, 2007 07:28 AM
