No wiper action
Old Dec 11, 2021 | 04:41 PM
E35062's Avatar
E35062
No wiper action
Looking for help to why my windshield wipers don’t work. 1996 E-350 cube van 7.3 diesel. Earlier this summer they would work very slowly. If I grab the wiper and kind of help it they would finally work . Now when I turn the switch I get nothing. I here a click on the passenger side when I activate it but the wipers don’t move. Checked all the fuses they are good. What would be my next step?
Old Dec 12, 2021 | 05:11 AM
JWA's Avatar
JWA
Your next step is testing the wiper motor itself---if original its 26 years old and they don't last forever.
Old Dec 12, 2021 | 12:49 PM
E35062's Avatar
E35062
Thanks for reply , I was kinda dreading that as I have to work outside as the cube van is to big to fit in garage.
Old Dec 12, 2021 | 03:45 PM
tabijan's Avatar
tabijan
Check the fuse too. A tired motor can draw high amps.
Can the wiper linkage be cleaned and lubed?
Sixto
07 E350 5.4 177K miles
Old Dec 13, 2021 | 08:37 AM
manicmechanic007's Avatar
manicmechanic007
Before replacing the motor
Which is what you need to replace IMHO
Touch an additional ground wire to the body of the wiper motor
Sometimes they take off and go with the wire
Used to have to repair the faulty ground on the older ones that grounded thru the mount bolts
Your 96 does not ground like that but test it anyway
I have never had to lube the wiper transmission or replace one on a van. They are pretty tough
Old Dec 14, 2021 | 04:22 AM
JWA's Avatar
JWA
Your experience not withstanding and regardless how tough it is lubricating the wiper linkage IS a good idea----it takes strain off the motor making it last longer.
Old Dec 14, 2021 | 05:10 AM
manicmechanic007
You see that in a book somewhere?
Old Dec 14, 2021 | 05:14 AM
JWA's Avatar
JWA
It comes from the same book of imaginary or made-up advice that says its not necessary or all that important to lubricate moving parts.
Old Dec 14, 2021 | 06:25 AM
manicmechanic007
Lubing the wiper transmission is in no service schedule I have ever read
As far as the imaginary? book
I have a Ford master cert (took 20 years of book work) as well as being a dealer tech
You have one too?
Old Dec 15, 2021 | 04:37 AM
JWA's Avatar
JWA
You have one too?
I do---mine also came from eBay or a flea market!
Old Dec 15, 2021 | 06:13 AM
manicmechanic007
My name is in the Ford registry as a Chassis master
orionambulance
Jun 20, 2013 05:45 AM
bowdog
1997 - 2003 F150
Jul 31, 2009 10:01 AM
tommowry
Dec 18, 2003 04:06 PM
