Floor Pans
Old Dec 10, 2021 | 05:25 AM
BradGilyard's Avatar
BradGilyard
Floor Pans
Is it safe to leave the fuel tank in the cab when welding new floor pans? I figured I can cover it with a welders blanket if needed.
Old Dec 10, 2021 | 07:56 AM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
I don’t weld. But, are you already removing the seat? Removing the tank is really not much extra work. I would at the least drain the tank, but would more likely just replace it if you are stripping out the cab anyway. Everything I now do to my truck, when possible, I want it to be the last time I ever have to do it,
Old Dec 10, 2021 | 01:12 PM
daveengelson's Avatar
daveengelson
IMO, I would not risk the possibility of causing a fire since the seats will be removed and there are only 3 bolts securing the tank. Easy to drain the tank at the fuel outlet and offers opportunity to clean the tank. also clean the drain passages in the cab corners behind the tank. Intend doing same on my 65 at the beginning of next year
Old Dec 10, 2021 | 03:29 PM
2dwoods's Avatar
2dwoods
personally if it had no leaks to put out fumes that's what get u ,I would cover it and weld ,now lets talk grinding sparks everywhere so just be careful
Old Dec 10, 2021 | 03:30 PM
2dwoods's Avatar
2dwoods
Tank is pretty easy to remove
DocRoche
Bronco II
Jul 10, 2015 06:11 PM
Becky_is_a_66
Oct 9, 2014 01:42 PM
RumbleFish13
1961 - 1963 F100 Unibody
Nov 19, 2011 01:35 PM
rchassie
Jan 22, 2003 11:21 PM
