Quick flashing directionals
Old Dec 8, 2021 | 08:24 AM
husqvarna's Avatar
husqvarna
I removed my Morimoto XB Hybrid LED's this morning, so I can sell them separately, instead of trading them in with my truck.
Lights always worked 100% in my truck. Well, I removed them, installed the factory halogens back into the truck, and now the directionals on both sides are quick flashing. Any ideas how to fix it? I'm trading in my truck within weeks to the dealer, once my truck gets here.
Old Dec 8, 2021 | 08:28 AM
Poncho450's Avatar
Poncho450
Dumb question. But did you look at both turn signals from the exterior to make sure they're working? All bulbs plugged in? Generally a hyper flash indicates a no or low voltage draw. Or as the BCM sees it, an "outage". And even if they are working I've seen the instrument cluster doing the hyper flash while they flash from the exterior is normal speed. But that was LED with no resistor added or FORScan adjustment made.
Old Dec 8, 2021 | 08:31 AM
husqvarna's Avatar
husqvarna
The rear directionals work, but the fronts are not working. They worked fine with the Morimoto lights in. Not sure.
Maybe just need to replace both bulbs for some reason? But of course I already put the truck back together. lol
Old Dec 8, 2021 | 08:36 AM
Poncho450's Avatar
Poncho450
Weird that both bulbs would pick the same time to expire. It can be a pain but you can change bulbs without dismantling.
Old Dec 8, 2021 | 08:44 AM
husqvarna's Avatar
husqvarna
you have to use the same factory directionals when you use the morimoto lights. And I forgot to take the turn signal bulbs out of the morimoto housing. So currently, I have no directional bulbs in my truck at all. Hence why it’s flashing🤣🤣🤣🤣🤣🤣🤣🤣
damn I’m laughing hard over this one 🤣🤣🤣
Old Dec 8, 2021 | 08:56 AM
h20camper's Avatar
h20camper
....I forgot to take the turn signal bulbs out of the morimoto housing. So currently, I have no directional bulbs in my truck at all. Hence why it’s flashing.
That would do it. Glad you remembered.
Old Dec 8, 2021 | 08:59 AM
husqvarna's Avatar
husqvarna
I guess at 41 years old, I’m already having senior moments. 🤣🤣
Old Dec 8, 2021 | 09:13 AM
h20camper's Avatar
h20camper
And I can assure you, it doesn't get any better.
Old Dec 8, 2021 | 10:03 AM
Poncho450's Avatar
Poncho450
Oh well. At least you found the solution!
Old Dec 8, 2021 | 01:09 PM
redford's Avatar
redford
FTE Leadership Emeritus
Amen brother!
BenFranklin
6.2L V8
18
Dec 23, 2025 07:03 PM
53deere
Feb 11, 2018 08:02 PM
78 & 87 Super Cab
Jul 24, 2014 05:42 PM
peachboy
6.7L Power Stroke Diesel
34
May 14, 2011 06:38 AM
sickchuck
May 2, 2005 06:51 PM
