Sponsored by: Real Truck
Super Duty Jack
Old Nov 4, 2003 | 12:02 PM
SDNick's Avatar
SDNick
Super Duty Jack
Hi All,
Sorry if this topic has been covered already.
I bought a slightly used 2003 F350, V10 CC this year. Last weekend when installing moulded mud guards on the rear, I needed to take off the wheels so that I could drill a hole in the fender. I pulled out the (I assume) stock jack mounted behind the right rear seat and found that it doesn't go up high enough to get the wheels off the ground. When fully extended the jack extends 13" and I need at least 14" to reach the axle. I went back to the dealer and they said that this was a 2 ton mechanical jack and we checked a similar vehicle on the lot and it had the same jack.
Am I missing something here? Can someone out there check how far their jack extends and confirm that I have the right jack? I don't have any special tires or lift kits on the truck.
Thanks for any help or insight.
Nick
Old Nov 11, 2003 | 07:10 PM
jbullfrog's Avatar
jbullfrog
I checked mine
I grabbed my little bity jack from behind the back seat of my 03' to check. It is just like the old jacks. It has a second stage that starts at 13" and extends to 16 1/2" at the base of the saddle.
Oh, and if you forsee using the factory jack more than once, invest in a drag link socket to fit the jack so you can run it back down with a drill.
I have always carried a hydraulic bottle jack in my truck toolbox. Ironically I only got flats when I had my toolbox out for some reason and had to use the little jack.
Old Nov 12, 2003 | 12:19 AM
cwb's Avatar
cwb
Buy yourself a Hi-lift. You should have no problems. I have the all cast 60" and it will lift the front of my psd with 40's. That's a lot of weight.
Old Nov 12, 2003 | 01:13 AM
Tlattin's Avatar
Tlattin
I jack under the axle, not the frame and have success with 35" tires. Could this be your issue?
Old Nov 12, 2003 | 09:34 AM
NoMo's Avatar
NoMo
I second CWB's suggestion of a Hi-Lift. Not only will it raise the truck for tire changes, but you can use it in a pinch to get out of a tough spot.
Old Nov 12, 2003 | 10:08 AM
narcicus's Avatar
narcicus
For those of you who have used the hi-lift where do you place the jack? It doesn't look like there are too many sturdy places to place the jack. Just curious.
Old Nov 12, 2003 | 10:18 AM
NoMo's Avatar
NoMo
I used the tow hooks up front and the corner of the trailer hitch in back.
Old Nov 12, 2003 | 10:51 AM
oppy's Avatar
oppy
Okay, dumb question: what is a Hi-Lift?
Old Nov 12, 2003 | 02:58 PM
Hjudge49's Avatar
Hjudge49
They used to be called "4 foot" jacks down here in the South. Just an old fashioned ratcheting bumper type jack, but longer. Not only good for changing a tire, but will lft the truck up enough to clear stumps, etc. Just jack it up , figure the right direction and push it off the jack. Hard on the chrome, but gets you unstuck.
Old Nov 12, 2003 | 06:26 PM
NoMo's Avatar
NoMo
Hi-Lift (www.hi-lift.com) is a brand name. Generic versions are often called "farm" jacks. They are extremely strong and very versatile. I've used mine to winch my truck out of the mud and pull fence tight.
Old Nov 12, 2003 | 06:36 PM
oppy's Avatar
oppy
Thanks. I've seen them at Farm & Fleet many times and I always wanted to get one.
Old Nov 12, 2003 | 08:08 PM
SDNick's Avatar
SDNick
Thanks Jbullfrog,
I found my problem, the jack was getting stuck once it hit 13" (4" away from happiness ). Once I cranked it harder it extended to almost 17".
I think I'll take your advice and get a hydraulic jack. This jack doesn't look too sturdy once it's fully extended.
Regards,
Nick
Old Nov 12, 2003 | 11:09 PM
cwb's Avatar
cwb
The greatest part about the hi-lift is the most expensive versionis only $60.00 in my town,
