6.0 is stalling
Old Dec 2, 2021 | 11:55 PM
Akunz7's Avatar
Akunz7
6.0 is stalling
Hey guys got a 2007 f250 just got a motor in the truck from a know mechanic drove the truck for about 4 days now it’s stalling out on me if i give it over 2500 rpm’s seems like it lacks fuel when trying to start back up changed icp, ipr, ficm is getting good readings has upgraded blue spring kit but the mechanic said lift pump or fuel strainer just not sure if that sounds right!
Old Dec 3, 2021 | 07:36 AM
thatpartsguy's Avatar
thatpartsguy
Are you experiencing a hard start after the truck is at running temp? Do you have an egt monitor/gauge? The reason I ask is because if your truck has a hard start or its running high exhaust temp it could be your HPOP or the ICP sensor could be leaking. I would definitely start by hook it up to a fuel pressure gauge.
Old Dec 3, 2021 | 03:46 PM
Akunz7's Avatar
Akunz7
no hard start icp is fine and no i don’t have a gauge on it egts
Old Dec 4, 2021 | 12:35 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
You might want to post over in the "1999 to 2016 Super Duty" forum instead of the "New Member Introductions" forum.
Welcome aboard!
Glseese
Nov 2, 2017 09:24 AM
TheBeave9
May 11, 2015 12:55 PM
NH-Hottie
Dec 20, 2003 12:03 PM
