Headlight issues!! Please someone help!!!
Old Dec 1, 2021 | 02:44 PM
Kountrygurl74's Avatar
Kountrygurl74
I am having headlight issues with my 05 F150. I have replaced the headlight switch, replaced fuses, used a test light to check electrical issues and I still don't have headlights. My park lights work and my fog lamps work but they don't work on the automatic setting. My instrument panel doesn't work either. I'm at my witts end at this point!!!
Old Dec 3, 2021 | 06:34 AM
sr1620's Avatar
sr1620
headlights
i have a 2005 f-150 on my truck it has a flashing red light on the dash it is called a sun sensor. i changed out switch and other things. i went to ford dealer and bought a new sunsensor.and replaced it simple to change out go to u tube for video. thats all it was.steve
Old Dec 8, 2021 | 06:12 PM
Kountrygurl74
I finally got my lights working. It turned out to be a fuse which is crazy because I had just checked the fuses and they were working fine. Thank you for the reply
Old Dec 10, 2021 | 03:37 PM
60DRB's Avatar
60DRB
Which fuse was it?
That could help some one else in the future.
Old Dec 20, 2021 | 03:16 AM
Anthonyawh's Avatar
Anthonyawh
Originally Posted by 60DRB
Which fuse was it?
The headlights are 2 separate stand alone fuses #23&25. The highbeams are 1 fuse #35
Old Dec 22, 2021 | 06:09 PM
Kountrygurl74
My apologies for taking so long to respond. I replaced the #35 fuse and the #25 fuse.
Old Dec 23, 2021 | 07:40 PM
pdqford's Avatar
pdqford
and did that fix the problem?
Old Jan 4, 2022 | 10:12 AM
Kountrygurl74
Yes it did.
Old Feb 3, 2022 | 08:43 AM
alidonkaka6's Avatar
alidonkaka6
Hello,
turkish citizenship
I was finally able to get my lights to operate. It turned out to be a blown fuse, which is strange considering I had just double-checked the fuses and they were OK. Thank you for your response.
western star
May 26, 2013 10:12 AM
mthorlakson
2004 - 2008 F150
Mar 22, 2013 02:43 PM
budman325
Mar 15, 2011 04:37 PM
MICBAR
Nov 30, 2005 07:57 PM
a564jim
Aerostar
Jun 30, 2004 07:25 AM
