Front end vibration
Old Nov 30, 2021 | 08:05 PM
Jnevrotski's Avatar
Jnevrotski
3rd Gear
Front end vibration
I replaced everything on the front end (almost) did both sides c-v axle shaft with differential seals, upper control arms (because ball joint is part of it, wheel bearing assembly, rotor caliper, brakes tie rod ends and drivers side lower control arm (not passenger) its not a rotational vibration because it would be every revolution of something like axle, bearing, drive shaft. It intermittent but now once i hit 50 its a steady vibration, its not in the wheel, i feel nothing indicating it in the wheel or pedal im stumped
Old Nov 30, 2021 | 10:24 PM
donjamer's Avatar
donjamer
Moved to appropriate forum
Old Nov 30, 2021 | 11:00 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
What is the condition of the tires?
How many miles on them?
Have they been balanced?
Have they been road-force balanced?
