Almost time for a spark plug change. 83,700 miles on it now.
Should they be changed ahead of the recommended 97,500 mile mark?
Any known issues or problems while changing them?
Thanks
how many miles on the truck?
as far as issues in changing the plugs, swivels will be your friend. its not hard just annoying to get the lower plugs out.
Pull the fender liners and go through the wheel wells for the lower eight plugs. It takes about 15 minutes but will save you tons of aggravation trying to access the lower plugs from up top or through the small opening in the liner.
Here is my story....most of the points have been covered by others already.
I used a dab of anti-seize when installing the NEW plugs...some don't believe in it...it's your truck.
What Qwazert said X2. Just dab a little on a Q tip. People who do not never seize a thread are just asking for a problem. I work in a chemical plant in maintenance...........oh my God at the horror stories on that subject alone.
Agree with pulling the fender liners. Makes the lower plugs very simple. Also change out the resistor “pills” in the coil packs, mine were all corroded up.
I bought this truck used a month ago.
The previous owners live in PA. Evidently the truck was exposed to a lot salt/brine road treatments during the winter months. which is to be expected.
Should I replace the plug wires and the ignition coils along with the plugs?
Thanks
Thanks
I would do it all while your in there but thats just me.
I just did my 2013. I did not remove the front wheel liners but wish I had after it was done. I replaced plugs, wires, pills and boots from RockAuto for about $160. That was with oem plugs.
I would look at the coils closely, but rebuilding the boots is probably the most you will need to do. Replacing the coils is overkill and expensive unless you know you have some going bad.
Exact same as I did on my 2011, but I pulled the inner liners. Rock Auto is my go to as well for this stuff.
Rear driver's side plug on top was worst for me.. LOL..
This is an awesome thread. I didn't know you could change the boots. I never saw the part number or separate item shown in the ford parts catalogs. So I thought it was coil or nothing. I have Motorcraft plugs and wires ready to go on my work bench. I just ordered new COP boots tonight from rock auto. I kind of forgot about them for stupid stuff like this. I also put in an email for returning the coils I purchased which I now know I can replace the boots them.
Thanks for the helpful insight.
***Also planning on attacking the lower plugs through the wheel wells but with the tires off. I planning on doing this at work in the warehouse. So I rather be toasty than frozen doing this. Plus the truck should be on the warm side for easier plug removal.
