Help me build my engine please!
Old Nov 28, 2021 | 07:43 PM
Alx2018's Avatar
Alx2018
I have no clue where to start to get the engine up and running. Anything helps
Old Nov 28, 2021 | 09:10 PM
ctubutis's Avatar
ctubutis
Welcome to FTE.
The title says you want to (re)build your engine, my first thought is to send you to the I-6 engine forum:
https://www.ford-trucks.com/forums/forum52/
If you're just wanting to get it running, well, there are guys here in 80-86 and probably also in the 1973-79 forum who can maybe help. But people are going to ask you for more information; what's wrong, what are the symptoms, what have you tried, things like that.
Old Nov 29, 2021 | 02:10 AM
FuzzFace2's Avatar
FuzzFace2
Also the year and what body & chassis is the truck.
I ask because that dose not look like a Ford motor as the carb / intake and distributor are on the wrong sides.
Looks like it could be a Chevy 250 six motor with Ford blue paint.
Dave ----
Old Nov 29, 2021 | 12:42 PM
5starCabF-3's Avatar
5starCabF-3
Fuel,fire,compression
regardless of manufacture
Do you have fuel in that Rochester carburetor?
if so pull off a plug wire and stick a screwdriver in it and hold it near ground. Have a friend crank it and look for spark
Old Nov 29, 2021 | 05:41 PM
Alx2018's Avatar
Alx2018
Dave ----
I have no clue its one of those mail trucks.. I have no idea the motor or anything that matters. I have spent alot of time searching what kind the engine this could be.
Old Nov 30, 2021 | 06:27 AM
FuzzFace2's Avatar
FuzzFace2
Yea the Rochester carburetors were not used on Fords, it's a Chevy carb.
It looks to have a new-ish fuel pump but no lines hooked to it?
Originally Posted by Alx2018
I have no clue its one of those mail trucks.. I have no idea the motor or anything that matters. I have spent a lot of time searching what kind the engine this could be.
You should have gotten paper work to get plates for the truck and on them should list the truck manf. like Grumman or something like that.
There should also be a body manf. plate some where on the body that can help us.
I also dont think US Mail used Ford parts in their trucks GM / Chevy parts.
But as sdelivery said Fuel,fire (spark),compression
regardless of manufacture and it should run.
Dave ----
Dave ----
F-1 Mac
Sep 14, 2021 11:36 AM
run6.0run
Jun 25, 2012 01:41 PM
Tyler S
38
Feb 16, 2012 10:36 AM
RA81222
1978 - 1996 Big Bronco
Aug 12, 2008 03:50 PM
