Error messages, please help, dealer can't fix
Old Nov 27, 2021 | 09:14 PM
2001F250_7.3's Avatar
2001F250_7.3
I am driving a 2018 F250 6.7L 4x4 King Ranch. I am getting three error messages on my dash cluster consistently. They pop up in all driving conditions and at all different speeds. I can hit okay on my steering wheel and clear them out but they come right back a few minutes later. The dealer has not been able to solve the problem.
1) Service AdvanceTrak
2) Hill Descent Control fault
3) pre-collision assist not available (however, it seems to be working because it beeps at me all the time when I get close to another car.)
Attached are pictures of the three warnings (sorry for the clarity.... I was taking the pictures while I drove). I am not running any programming on my PCM. It is in an all "stock" configuration. The only modifications to the vehicle are a cat-back mbrp exhaust system and a cold air filter.
I recently purchased the Forscan interface cable for my laptop and downloaded the software. I have never used for scan and am a little bit scared! Does anyone have any guidance for me? Please help.
Old Nov 27, 2021 | 09:29 PM
morehouse7's Avatar
morehouse7
Check the plug up under the rear on the passenger side frame next to the spare tire? Clean and grease it, see if that's it
Old Nov 27, 2021 | 09:30 PM
GMB Racing's Avatar
GMB Racing
Wheel ABS sensor
Old Nov 27, 2021 | 11:03 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Yeah, it looks like it could have something to do with the ABS as all three fault messages are electronic brake related.
Possibly a faulty ABS module.
There should be error codes showing on a scan.
If the dealer can't track it down, sounds like an inexperienced tech, try another dealer or a good independent shop.
Old Nov 28, 2021 | 07:20 AM
Log Hog Kust'em's Avatar
Log Hog Kust'em
I had similar problems with a 2015 (except the pre-collision) It would hang around a couple of day and go away for a few months. I solved the problem by trading it for a new one
Old Nov 28, 2021 | 07:29 AM
fordboy424's Avatar
fordboy424
Pressure sensor in hcu might be biased. You can use forscan to check the brake pressure. Should be zero or very close when there is no input from the pedal.
Old Nov 28, 2021 | 07:39 AM
senix's Avatar
senix
Also check the connections around the E-Brake. They have been known to cause issues too.
MARCUSO
2015 - 2020 F150
Sep 6, 2021 11:24 AM
linnwgetin
Mar 26, 2020 01:01 PM
hdman6
6.7L Power Stroke Diesel
13
Mar 3, 2020 01:29 PM
jwrco2000
111
Feb 1, 2019 04:41 PM
Deluxe06
30
Oct 21, 2010 07:03 PM
