Low oil pressure after rebuild (5.4)
block sent to machine shop i installed new
Piston and rings
Oem crankshaft
After market bring set
Oem oil pump
2 remam heads
Truck start up and sounds good oil pressure 55psi after 6 minutes drop to 10psi oil light come on then pressure drop to 0.
