Remote start question
Old Nov 24, 2021 | 07:11 AM
Frank79's Avatar
Frank79
When utilizing the remote start feature on your truck, the air conditioner turns on unless you manually turned it off before getting out of the truck.
when the feature in your dash is set to turn on at the last setting this could either be on the air conditioner mode or heater mode depending on where you left it before turning the truck off.
when the feature is set to automatic, at what temperature does the truck turn the air conditioner on or the heater on?
Old Nov 24, 2021 | 07:16 AM
.Axl's Avatar
.Axl
I could be wrong but I believe that's based on what temp you've set via your temp control **** relative the the interior temp. IE If the interior temp needs cooled off or heated up.
Old Nov 24, 2021 | 07:23 AM
tshank90's Avatar
tshank90
I've only had my 22 for few weeks and haven't quite figured this out either, I usually turn off my A/C before I shut down, but have noticed when I use the remote start if its cool outside the seat heat and the steering wheel heat come on, if its hot the seat A/C comes on.
Old Nov 24, 2021 | 07:27 AM
Frank79's Avatar
Frank79
based on that I think your settings in the dash is set to automatic climate control.
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
It depends on what settings you have entered in the menu as to whether the hvac and seat and steering wheel heat are turned on with remote start or not.
Old Nov 24, 2021 | 07:29 AM
Frank79's Avatar
Frank79
I have not seen those settings in the menu.
when I go outside here shortly I’ll take a picture, but if I remember correctly I believe it says “automatic” or “last setting.”
Old Nov 24, 2021 | 07:46 AM
05F250DSL's Avatar
05F250DSL
thats all I got auto or last setting. Seem near 40-45 degrees F I notice that my heated seat is on.
Old Nov 24, 2021 | 07:58 AM
Frank79's Avatar
Frank79
This is all I have.
Old Nov 24, 2021 | 08:03 AM
FreshPow's Avatar
FreshPow
It makes sense that you should leave the temp on auto with no overrides and that would warm up instead of cool down.
I've searched the forums, but I'm still not 100% sure that you can remote start any new truck with Ford Pass even if it doesn't have remote start feature. True?
If so, does Ford Pass use Blue Tooth, Wifi or satellite to communicate with the truck?
Do you need a subscription?
Old Nov 24, 2021 | 08:08 AM
Mlarv's Avatar
Mlarv
Ford Pass uses cellular date. None of the others except Satellite have the distance.
Old Nov 24, 2021 | 08:10 AM
Frank79's Avatar
Frank79
I Remote start mine with FordPass all the time if I’m in the house or in the store.
Old Nov 24, 2021 | 08:24 AM
FreshPow's Avatar
FreshPow
I would translate that to it is a paid subscription because the truck acts as a phone on the cell network.
Old Nov 24, 2021 | 08:38 AM
Mlarv's Avatar
Mlarv
Nope you do not pay for it. It is built into the cost of the truck at purchase. The F150 folks have been adding the modem to their trucks for a few years now.
Sync Connect
Old Nov 24, 2021 | 08:46 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
This is all I have.
The setting for remote start on the radio screen settings tab is what you need to change the climate with remote start settings, not that instrument cluster setting.
Old Nov 24, 2021 | 08:58 AM
Frank79's Avatar
Frank79
wrong…
bought my truck in 3/2021. Have 8k miles and never activated the modem in the truck, yet I am able to lock/unlock and start the truck from ford pass
