Sponsored by: Real Truck
6.0 won’t move
Old Nov 19, 2021 | 09:22 PM
retardedmechanic101's Avatar
retardedmechanic101
6.0 won’t move
I have a 2006 6.0 with the 5r110w trans and i was driving and got on it a little bit to pass someone and it is like it went into neutral I replaced the torque converter and put it all back together still doesn’t work I can put it in any gear and it will not move at all please help me
Old Nov 20, 2021 | 06:15 AM
Donny6.0's Avatar
Donny6.0
you might want to check the solenoid's did you check the input shaft while putting in the new converter? they can break easily with hitting the gas hard. Putting in a new converter i would've put a billet input shaft in its a lot of work put a converter in. id start with checking with line pressures
Old Nov 20, 2021 | 02:50 PM
redford's Avatar
redford
FTE Leadership Emeritus
Is your truck 4WD? If so, don't overlook the transfer case as the cause.
Old Nov 22, 2021 | 05:21 PM
retardedmechanic101
how do I tell if the transfer case is messed up
Old Nov 22, 2021 | 06:06 PM
Old and soft's Avatar
Old and soft
When the truck is placed in park, does it move?
takotruckin
24
Nov 20, 2021 06:29 AM
miner999r
Dec 16, 2012 12:52 PM
Awmjr05
Apr 19, 2012 01:00 AM
deemac
May 27, 2009 09:01 AM
Intense_Spence
Jan 24, 2009 04:10 PM
