Bed misalignment
Old Nov 19, 2021 | 08:48 AM
Nagle's Avatar
Nagle
Trailering
Bed misalignment
I have a 97 f-250 extended cab. The bed is severely mis aligned and I’m wondering what could cause this. Truck is pretty rust and I noticed the bed is sitting on the frame on one side but cab seems to be in line with the axles.
Old Nov 19, 2021 | 09:07 AM
Rusty05's Avatar
Rusty05
4wd Low
Which side is the bed sitting on the frame? Driver side?
I would guess you either need new cab mount bushings or new rails under the bed. Possibly both need replacing. I had a bed alignment issue and new cab mount bushings fixed the problem but it wasn't nearly as bad as your Pic shows. Can you post a pic from the rear of the truck? Try to show bed to bumper and bed to cab alignment.
Old Nov 19, 2021 | 12:00 PM
Nagle's Avatar
Nagle
Trailering
from the video I received from the owner (looking to buy the truck it’s a great deal but wondering if this could be why) it appears that bed is sitting on frame in the side that it is higher on. Makes me wonder if it’s bad suspension on driver side. One of the cab mounts does look horrendous. I will add some picture of bed to cab, cab mount, and bed mount
Cab mount 🤮
Bed mount looks pretty bad too
Old Nov 19, 2021 | 12:04 PM
Nagle's Avatar
Nagle
Trailering
This is the only picture I have with bumper in it, can’t tell too well if it’s aligned with cab
Old Nov 21, 2021 | 10:12 PM
wkf94025's Avatar
wkf94025
I would pass on that truck, based on a number of your photos. Cancer looks fairly advanced.
Old Nov 22, 2021 | 06:20 AM
97-psd's Avatar
97-psd
Unless you are willing and able to do some serious rust repair, I would pass. As you noted, this is probably the reason it is such a good deal.
Old Nov 22, 2021 | 10:05 AM
Nagle's Avatar
Nagle
Trailering
Thanks for the input! I did end up passing on the truck
whirledpeaz
Jan 9, 2018 03:54 AM
1970F250
Apr 20, 2012 10:07 PM
doug70
Sep 11, 2010 06:48 PM
sp007
Jul 27, 2003 10:22 PM
