Hinge Wrench ideas???????
Old Nov 17, 2021 | 09:30 PM
tbear853's Avatar
tbear853
The door hinges on my '77 .... I can get to the 6 bolts to adjust at the hinge to door point, it's them 6 at the other point where the hinges bolt to the cab itself I need to figure out ... guess I'll be making a 1/2" wrench to loosen to adjust and then tighten them tomorrow. What configuration do y'all whom do it often find useful?
Old Nov 18, 2021 | 04:37 PM
tbear853's Avatar
tbear853
No one had a favorite I see. Today I took two different old double ended 12 point 1/2-9/16 box wrenches, did a little cutting, welded them, the 9/16 end let me use a 1/2" steel bar inserted as a little extra leverage. I fully rxpected the use of the steel bar might break a weld .. but it didn't. The wrenches give me reach with the door open to get to those three bolts holding hinges to the cab. The deeper one let me get over the near bolt and onto the far bolt, the shallow longer one worke well too but the shorter one got the most use. They let me get to the bolt heads while clearing the painted door. I might smooth the outer edge of the weld.
I have a few others unmolested, I buy wrenches with labels like "Vanadium" on them at antique shops, good steel. Model A Fords had a lot of vanadium steel in axles, spindles, etc ... why they are so tough. I'll include this pic,. might help someone else some day. I used E7014 3/32" rod on AC @ 90A ... and now I have hinge wrenches.
Old Nov 18, 2021 | 09:24 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
That turned out pretty cool, good job. Nice custom set up, like my distributor wrench I made.
Old Nov 19, 2021 | 11:37 AM
Peter Gozintite's Avatar
Peter Gozintite
bookmarked! Thanks for the pictures. I have a bunch of old wrenches, and will be making a couple of these. Already have a homemade dizzy wrench.
Old Nov 19, 2021 | 11:38 AM
Peter Gozintite
is there an echo in here? hahaha
Old Nov 19, 2021 | 12:47 PM
Meridian_Mike's Avatar
Meridian_Mike
COOL.... I have to remember this idea.
SO, does a distributor wrench work in this situation? What size are they?
Old Nov 19, 2021 | 04:47 PM
tbear853's Avatar
tbear853
1/2" .... I have a distributor wrench, couldn't get near the bolts I made these for.
Old Nov 22, 2021 | 08:11 AM
Meridian_Mike
Good deal....
The pawn shops around here have SEVERAL old wrenches in bins where you can just go pick out a couple and modify them.
(I need to go wrench shopping!!!!)
Thanks for the idea!!
Old Nov 22, 2021 | 09:54 AM
77&79F250's Avatar
77&79F250
Not on my part anyway, I posted that statement before you. So there nanabooboo.
sklbaj
Sep 11, 2021 08:13 PM
pogo619
Dec 6, 2020 08:39 PM
ForCal
Feb 25, 2020 09:07 AM
oldracerjones
Jan 6, 2020 03:30 PM
oldracerjones
Jul 23, 2019 02:07 PM
