Every now and then my truck will while at a stop light feel like someone just bumped me in the rear end. The yellow wrench light comes on but still lets me drive it. If I shut it off light goes away. This has happened for a while and at last service our shop did an update to computer. That did not fix as it just did it again. Anyone else have this problem? Thanks and I did search this out for about 20 minutes with no luck.
First thing to do is have the code read while it's on. Or get started with Forscan and read it yourself.
Just asking if anyone else had same problem and what it was. This is a work truck with all my tools on it so laying it up for more than an oil change is a pain. Thanks.
Taking it in without the light on will be a waste of time. I would call the shop and tell them what's happening. Ask if you can stop by the next time the light is on so they can get the code.
Normally the codes will be stored in non-volatile RAM even if the check engine light is not on. It will be there until you disconnect the battery for a while. That is how old vehicles work at least.
