Light steering after leveling kit
Old Nov 16, 2021 | 09:08 PM
Nlara1013's Avatar
Nlara1013
I have a 2020 Ford F-350 srw and installed a 2.5 readylift leveling kit with carli 2 degree caster bushing and now my steering lighter turning left and normal to heavier turning right. I don’t have adaptive steering but do have the electric hydraulic assist. Is there something in the steering that can be recalibrated and is anyone having this problem. I didn’t have this issue when it was stock.
Old Nov 17, 2021 | 07:03 AM
Log Hog Kust'em's Avatar
Log Hog Kust'em
I have always been told to get the front end aligned after doing any front end work like leveling. A front end inspection that goes with an alignment will be able to tell you if something is not right
Old Nov 17, 2021 | 07:27 AM
Sox3's Avatar
Sox3
Did you get the kit with the track bar relocation bracket?
Old Nov 17, 2021 | 07:35 AM
rjacobs's Avatar
rjacobs
light steering is generally not enough caster... but something else could be off.
Old Nov 17, 2021 | 08:01 AM
JHForman812's Avatar
JHForman812
I have read the track bar relocation bracket will increase bump steer and make the steering feel lighter. I had a 2.5 kit on my 19 with the relocation bracket and i can tell you that bump steer was a lot, and the steering felt extremely light. My 22 I used a 1.5" kit and an adjustable track bar, my 22 drives exactly how it did when i brought it home from the dealer.
Old Nov 17, 2021 | 09:58 AM
Nlara1013's Avatar
Nlara1013
I had the track bar relocation bracket but offset my axle to far to the passenger side so I bought the adjustable track bar and now it’s perfect. It can’t be lack of caster since it’s has the 2degree caster bushings and it’s only light steering turning to the left only.
Old Nov 17, 2021 | 10:05 AM
Nlara1013's Avatar
Nlara1013
I did but offset my axle to far to the passenger side so now I have the adjustable track bar.
Old Nov 17, 2021 | 10:44 AM
rjacobs's Avatar
rjacobs
Have you had it on an alignment rack since you did all the work?
Can the caster bushings rotate or do they only install one way?
Old Nov 17, 2021 | 11:30 AM
Nlara1013's Avatar
Nlara1013
yes I've had it aligned and the bushing cant not be rotated. Not sure if the steering angle sensor has something to do with it.
Old Nov 17, 2021 | 11:38 AM
Norcalpr's Avatar
Norcalpr
Yep. From factory the track bar/panhard angle matches the drag link, so as the axle travels in a arc when it goes up and down, the steering follows. If you drop one but not the other, now they're unequal and you get bumpsteer.
Just do one or the other. Throw the factory panhard bracket on..
So what's the alignment numbers? Some bushings have a hex head on the top so it is possible. You might have some camber on one side vs the other. Steering angle sensor would have nothing to do with it, its just a sensor...
Old Nov 17, 2021 | 02:42 PM
Nlara1013's Avatar
Nlara1013
It had the readylift track bar bracket but since it offest the axle to far to the passenger side its been taken off factory one was put back on now has adjustable track bar and I dont have an issue with bump steer. The computer has to communicate with the steering If i make a fast right hand corner the steering gets firmer and if i make a fast left hand corner not as firm, If im at a complete stop and turn either right or left no difference in feel.
WVsuperduty2020
Apr 25, 2021 09:21 PM
WVsuperduty
Apr 20, 2021 09:02 PM
Campbellsoutlaw
Aug 26, 2019 02:51 PM
