Sponsored by: Kumho
What up with this?
Old Nov 3, 2003 | 09:21 PM
onebadbanshee91's Avatar
onebadbanshee91
What up with this?
I just installed my Rough Country 4 inch lift kit on my 1995 Ford Ranger and now my front wheels are doing this \ / . What happen? Can this be adjusted or do I need to buy something? I also still have the stock front wheels and tires and wheels on.
Old Nov 3, 2003 | 10:27 PM
Boheefus's Avatar
Boheefus
is that the ttb front axle? if so, you need to adjust the camber of the tires. rough country should have included drop down brackets for the pivot point. If it is a straight IFS, then I would go over the directions again and see if they expect you to tighten the torsion bars..
Old Nov 4, 2003 | 03:14 PM
natewoz's Avatar
natewoz
You may need an alignment. The brackets drop the axle down, but doesn't get as precise as needed for good tire wear and vehicle tracking. Since you installed the kit, the whole front suspension is most likely out of alignment. If you havn't got it done, you should probably do it. Also, the \ / should lessen as the springs settle. Hope this helps.
