Ignition System type
Old Nov 13, 2021 | 11:02 AM
PRIMERED79 SHORT BED's Avatar
I have a 1992 f150 302 five speed 4x4 and forgot what type of ignition system these truck use? can somebody refresh my memory please.
Old Nov 13, 2021 | 11:16 AM
SFaulken's Avatar
SFaulken
It's Fords TFI ignition setup.
Old Nov 13, 2021 | 12:33 PM
subford's Avatar
subford
It has an EEC-IV.
You also have the Push-Start Ignition system.
Attachment 279104
Attachment 279105
Attachment 279106
Old Nov 13, 2021 | 05:34 PM
Thanks for replies guys, quick question, do all spark plug manufactures use they same standard to determine heat ranges?
I ask because I'm trying to experiment with creating a hotter spark using 0 ohm wires and non resistor plugs.
I bought some Accel 276S plugs (non resistor) with a heat range of 6 but had to return it back to the NGK UR45 (resistor) with heat range 4 because it was acting like it had a misfire.
After keeping the 0ohm wires and NGK UR45(resistor) plugs it runs fine, so the only thing I can think of is the heat range is different.
Old Nov 13, 2021 | 06:40 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Are the standard plugs fouling and with what: oil, fuel?
Old Nov 13, 2021 | 07:10 PM
No fouling, just doing a upgrade to the current ignition system.
Old Nov 13, 2021 | 09:43 PM
SFaulken's Avatar
SFaulken
No, all spark plug manufacturers indicate their heat ranges differently. I don't recall which is which. But generally speaking, you shouldn't need to be messing with heat ranges, unless you're getting oil or fuel fouling. A "Hotter" spark plug has *zilch* to do with the spark the plug produces. It's basically an indication of the heat range at which the spark plug will remain "self-cleaning" and not load up.
Old Nov 13, 2021 | 11:26 PM
I was thinking the heat range was effecting the performance of the new non resistor plugs I tried running, but it looks like non resistor plugs in these trucks are a no no, either that, the anti seize I used on the threads was causing the misfire.
bountyhunter1650
Jan 26, 2016 04:56 PM
chrison600
Apr 9, 2011 10:22 PM
1950ford
Sep 6, 2005 11:24 AM
ROMEO4894
Computer Chips & Tuners
Mar 16, 2002 02:14 PM
ROMEO4894
Feb 21, 2002 09:27 PM
