Electrical hell
Old Nov 13, 2021 | 08:20 AM
Mrifle's Avatar
Mrifle
Electrical hell
Hey guys,
let me apologize that I'm new to being a auto mechanic. I started my engine rebuild with my brother and finished it. My two children couldn't believe it when it started for the first time. I cried.
I'm to the electrical hell of turn signals, lights, horn. . .WTH!
My problem seems to be mainly the drivers side. I have done the obvious steps sockets, bulbs, fuses. I ordered a new turn signal harness as my next fix. I pray that from what I've read that the TSS could effect the lights. 🤞
The grounds. I guess I think they look like grounds screwed to the body. How do I know when my ground is bad?
Thank you for all the info. In this forum it has helped tremendously.
P.S. I have my timing around 22* btdc but my idle is high and jerks into gear. I think I have my idle screw as far out and seems it doesn't reduce the idle. When I adjust the timing to a sweet idle it runs like crap bogging and chocking.
Thank you guys for any help.
Please be kind this is my first rodeo.
Old Nov 16, 2021 | 07:23 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Scroll down from the main page to the engine you overhauled. This is the wrong place to get your issue answered.
Old Nov 16, 2021 | 04:23 PM
RLXXI's Avatar
RLXXI
and/or post in the section of your year model truck which you might mention as no one is going to be able to help you without knowing what you're working on.
Old Feb 4, 2022 | 07:07 PM
BLUE79SHORTY's Avatar
BLUE79SHORTY
My Electrical hell solved.
I had a similar problem. I had no side marker lights ,tail lights or reverse lights my turn signals wouldn't work as soon as the head lights were turned on.I checked grounds added grounds checked wires and sockets and found nothing.
I took it to my friends garage and put it on the lift.
my friends son checked the wires for like 30 seconds
looked back at the trailer hitch plug and said I but it's in that mess . He pulled it a part and found it was done wrong. He fixed it. Total process took 10 minutes. Ever light and turn signal work now.
chuckieboi
New Member Introductions
Mar 21, 2008 04:30 AM
mike L
21
Feb 13, 2006 10:33 PM
jonm61
Oct 4, 2004 02:16 PM
