Transmission woes!!!!
Old Nov 3, 2003 | 08:24 PM
waren's Avatar
waren
Unhappy Transmission woes!!!!
I just bought a 79 F-150. It has a 302 with a C-4 tranny. The truck was parked for four months and now will not take drive,but has reverse strong.Man said was fine when parked. First Question what's wrong? I plan on pulling a camper of at least 25 foot with the truck. Is the C-4 strong enough to do this.If my tranny needs replaced should i put in a C-6. Would it be an easy change over if i chose this option?
Old Nov 3, 2003 | 09:06 PM
79 250 lariat 4x4's Avatar
79 250 lariat 4x4
apparently the C6 was the toughest automatic tranny built by ford.
Old Nov 4, 2003 | 11:12 AM
stepman's Avatar
stepman
Sounds like you lost your "forward" clutch. How's the fluid? Dark and burnt smelling? The C4 is a pretty tough little trans too. Don't know how good they are for towing though.
Old Nov 4, 2003 | 08:07 PM
waren's Avatar
waren
Thanks guys !! Today i tried a new filter and some trans conditionor but still the same problem.The old fluid was not really burnt though.
Old Nov 5, 2003 | 09:57 AM
stepman's Avatar
stepman
If it feels like it's in neutral when you do that, it probably burnt up the forward clutch. If it feels like the brakes are locked up, then you burnt the reverse clutch. If you are mechannically talented, you can rebuild it for about $100.00 . That's about what a "clutch and seal kit" runs. Have to have a couple "special tools" though. There are usually some in the paper that say rebuilt for 150-200....That's what someone is doing out of their garage. Helps to know a little about autos too, you don't want to open it up and start dropping check-***** and springs eveywhere.
