Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
vin help
Old Nov 11, 2021 | 12:42 PM
jonny9117's Avatar
jonny9117
7th Gear
vin help
what rear end do i have or any information would be helpful thanks
Old Nov 11, 2021 | 07:51 PM
85e150's Avatar
85e150
Next week, I'm out of town.....
Old Nov 17, 2021 | 09:23 PM
85e150's Avatar
85e150
C85 = C850
L = 534 4V Super Duty gas V8
U = Louisville Assembly Plant
A32392 = 1967 series number. (this also works for 1976, BUT there is no C85 or model C855 for 1976, and the assembly code would be V, for Kentucky Truck which is where all these were made after 9/69, and there would be a front axle code) (October 1966 production)
153 = 153 inch wheelbase
J = Red
C855 = C850, 27,500 lbs GVWR, "Except State of PA"
A91 = Possibly Custom Cab, my info is limited on this. Upholstery and seat type are all figured using this, but again, I don't have it.
N = Dana (Spicer) model 6352 five speed direct transmission
4K = Eaton model 1880 single speed rear axle, 22,000 lbs capacity, 6.50 ratio (I had a tough time finding this one as my resources are limited. Confrim you do have a single speed axle. You can find ratio and model number on the carrier casting above the pinion and stamped on the driver side axle housing.)
No front axle code, meaning it's probably the "standard" front axle, with a capacity of at least 6,000 lbs.
27500 =27,500 lbs GVWR
235 3000 = 235 certified net HP @ 3000 RPM
740033
74 = Seattle District Code
0033 = Special Order number.
Old Nov 17, 2021 | 09:36 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 85e150
A91
A91: A = Light Gray Crush Vinyl & Gray Twill Stripe Woven Plastic // 91 = 91B Custom Cab
Old Oct 20, 2022 | 01:47 PM
jonny9117's Avatar
jonny9117
7th Gear
vin help
hello , vin c85lua32392 ,, thanks for your help
Old Oct 20, 2022 | 03:01 PM
85e150's Avatar
85e150
Merged with this older thread where the whole plate is decoded.
Added an update or two as well.
Cliff Ragan
Sep 5, 2021 10:16 AM
Johnytrucker
Large Truck
Jul 27, 2021 01:26 AM
J_Remy
Jun 29, 2021 03:12 PM
Rusty Fords
Apr 27, 2020 10:47 PM
