axle question
Old Nov 10, 2021 | 01:32 PM
wizardfitz's Avatar
wizardfitz
axle question
Building a 22 f250 lariat 4x4 Supercrrw 8ft bed, 7.3 engine. Comes with 3.55 gears, if I add fx4 it changed gears to 4.60.
Why? Benefits?
Will not be towing.
Old Nov 10, 2021 | 01:37 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
There is no 4.60 ratio, there is 4.30.
Lower ratio is good for offroad use, better if you plan to lift and add taller tires.
Never spec'd a gas engine truck myself, don't know why that package would force the lower ratio on it.
Old Nov 10, 2021 | 02:33 PM
shawnee1's Avatar
shawnee1
The FX4 package requires the electronic locking rear axle. For the 7.3 I think it is either a 3.55 or a 4.30. If you don't select an electronic locking the build defaults to the 4.30 for the FX4 package but you can change it to the 3.55 or select the 3.55 electronic locking before selecting the FX4 package.
Old Nov 10, 2021 | 03:20 PM
wizardfitz's Avatar
wizardfitz
that worked thanks
Old Nov 10, 2021 | 05:09 PM
05F250DSL's Avatar
05F250DSL
Why? Benefits?
Will not be towing.
as far as benefits 4.30’s will give better acceleration, as mentioned if you plan on bigger tires it’s not a bad idea. You will have more smiles with the lower ratio and reports on mpg have been little difference between the two.
Old Nov 10, 2021 | 06:04 PM
Sox3's Avatar
Sox3
Old Nov 10, 2021 | 06:21 PM
akajones's Avatar
akajones
I ordered 4.30s, but the truck does turn some serious Rs at highway speeds. More engine wear from Rs with the higher speeds is a small downside. I was willing to make that trade. These trucks have plenty of power for either ratio IMO.
Old Nov 10, 2021 | 06:39 PM
00t444e's Avatar
00t444e
Get the 4.30 gear ratio, with the new 10 speed you can still cruse at low rpms with 4.30 gears.
Old Nov 10, 2021 | 08:03 PM
Johnny Paycheck's Avatar
Johnny Paycheck
I’m not sure you’re getting any wear at all as far as higher RPMs. These newer fuel injection setups are so precise, it’s not like the old days of pumping gas pedals to prime carbs and washing oil off cylinder walls. A few extra revs may have that oil pump moving a bit more oil where it needs to go.
Nov 9, 2017 02:06 PM
JOPAS
Mar 22, 2005 10:52 PM
oricle
Nov 3, 2004 07:43 PM
hcf250
Sep 24, 2004 04:55 PM
disappointed
Mar 24, 2002 11:30 PM
