Installing Temperature Sending Unit
Old Nov 9, 2021 | 04:54 PM
iwals's Avatar
iwals
I just tested the temperature sending unit on my '83 F150 5.0 L and it appears to be bad, so I ordered a new Motorcraft sending unit. I've read conflicting advise about wrapping the threads in teflon tape. It looks like they come with some kind of treatment on the threads already. How do you all do it?
Old Nov 9, 2021 | 05:00 PM
Franklin2's Avatar
Franklin2
Use what they have, don't add any. You simply need a good ground connection to the body of the sender. So try not to interfere with that if you can help it. You can take a ohmmeter and check it after you install it by putting one lead on the body of the sending unit, and the other lead on the engine block.
Old Nov 10, 2021 | 09:51 PM
Rusty_S's Avatar
Rusty_S
That red dry paste is thread sealer. Just thread it in as is.
If you do have to apply thread sealer on any sensor avoid teflon tape and pick up thread sealer paste such as ARP`s thread sealer which is a semi gritty feeling paste that you put a thin layer on the threads it will seal but will not prevent the sensor from grounding.
Like wise never under no circumstance use teflon tape on fittings that is used for the fuel system.
fubar25827
General Diesel Discussion
Oct 29, 2010 07:53 PM
hugger94
May 21, 2009 12:01 PM
t.Rowley
Nov 2, 2007 12:32 PM
