Wheel bearing seal direction
Old Nov 6, 2021 | 09:19 AM
8pack's Avatar
8pack
Which way does the wheel bearing seal go in on the back of the hub? The way I have it in or the smooth side up?
I couldn’t get it to seat with the smooth side up and it went in very nicely the other way but I thinking might have it wrong.
thanks!
Old Nov 6, 2021 | 10:28 AM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
The larger flat metal side faces "away from/to the outside of" the grease compartment. As such, I believe the one installed in the hub is incorrect.
Old Nov 6, 2021 | 10:41 AM
ALBUQ F-1's Avatar
ALBUQ F-1
You are correct
Old Nov 6, 2021 | 02:20 PM
CharlieLed's Avatar
CharlieLed
Spring is always on the "wet" side...
Old Nov 6, 2021 | 05:50 PM
8pack's Avatar
8pack
Thanks guys. Now I have to get it out!
Old Nov 7, 2021 | 06:47 AM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
Usually comes out without damage if you put the hub on the spindle, with only the inside bearing and seal in, put the spindle nut on and give the hub a decent jerk like your taking it off. The spindle nut catches the bearing and then the bearing kinda uniformally try's to keep the seal where it is, thus pulling bearing and seal with minimal to no damage to either.
I reread this and it's not as easy to understand as I'd hoped but hopefully you can understand what I'm describing.
Old Nov 7, 2021 | 07:35 AM
8pack's Avatar
8pack
Thanks! I think I got it, basically using the nut as a striker from the back side to get it out. I may try that this week if I have time. Otherwise I will do it in the spring.
Daneman
Feb 26, 2020 01:49 PM
Boondoggle99
1997 - 2003 F150
Jan 3, 2020 06:36 PM
peglegger
Dec 6, 2013 07:43 PM
ericconn
Oct 20, 2013 10:56 AM
