A girl needing help
Old Nov 6, 2021 | 08:49 AM
Kelly Ann's Avatar
Kelly Ann
A girl needing help
I have a 2015 F350 that the regen control is at its limit. I am having to drive my truck as a daily driver and have noticed that it will want to clean the exhaust but I am 1 minute from work. Check engine light is on. Average milage is 12.2. What can I do?
Old Nov 6, 2021 | 09:27 AM
Painted Horse's Avatar
Painted Horse
Go for a drive and take the long way home when ever you see that
Old Nov 6, 2021 | 10:36 AM
The Bone's Avatar
The Bone
You cant just let this go. You need to ether drive the crap out of it or buy a beater to go to work in. At this point your truck never gets to operating temperature and in turn you are killing your truck. They need to get hot to be efficient. Please don't drive your truck for one minute and shut it off and dont leave it idle in the driveway. That isn't good ether. It may be time for a opil change as well. This is what we call severe duty maintenance required.
WQe would like to se a picture of your truck. You can be in it if you like.
Old Nov 6, 2021 | 06:31 PM
Kelly Ann's Avatar
Kelly Ann
Thank you so much. I will look into the opil change next week and yes I agree on another car as well.
Old Nov 6, 2021 | 07:03 PM
lynnmor's Avatar
lynnmor
I wouldn't fire up an internal combustion engine for that short distance, weather permitting I would ride my bike.
Old Nov 7, 2021 | 02:33 AM
Fefanatic's Avatar
Fefanatic
What will happen if you don't drive it a message will come on the display exhaust filter full, drive to clean. If you don't it will go into reduced power mode and then you will really have issues. Generally speaking it takes about 20 miles for a full clean of the DPF. You need to get it done before you have bigger issues.
Old Nov 7, 2021 | 09:49 PM
00t444e's Avatar
00t444e
Delete the DPF, SCR and EGR.
Old Nov 8, 2021 | 07:41 AM
speakerfritz's Avatar
speakerfritz
get forscan and do periodic operator commanded regens
Old Nov 8, 2021 | 10:00 AM
Pugga's Avatar
Pugga
Personally, I tend to agree with this for the overall health of the diesel engine however, this is terrible advice to give to someone who's not a 'car person' and understanding of what the process entails.
Old Nov 8, 2021 | 02:29 PM
'65Ford's Avatar
'65Ford
That and the OP is still only driving a mile or so...not enough time to heat up the oil and drive out moisture = sludge
Old Nov 8, 2021 | 02:31 PM
00t444e's Avatar
00t444e
Yeah toxic sludge LOL.
Old Nov 8, 2021 | 02:58 PM
'65Ford's Avatar
'65Ford
Yep...
https://www.ford-trucks.com/forums/1...-6-7-help.html
Old Nov 8, 2021 | 06:54 PM
BC2019F250's Avatar
BC2019F250
I need to ask a question. Is your drive to work 1 minute or is the truck saying it needs to do a regen when you are in the last minute of your drive to work?
Old Nov 9, 2021 | 06:09 AM
Dirthawg2.0's Avatar
Dirthawg2.0
I thought I was the only one misunderstanding how far her commute was. Certainly her commute is farther than one minute from the house. These trucks are notorious for starting a regen as we arrive to our destination. That is how I understood that statement.
The truck would not attempt a regen if the commute was actually 1 minute of run time because the minimum coolant temperature would most likely not be up to temp yet.
It will be a surprise if she returns, last seen 3 days ago.
Jnsquires
Aug 3, 2020 01:46 PM
Joehurd
6.4L Power Stroke Diesel
Jan 11, 2016 09:03 AM
DomsDad
May 23, 2015 03:29 PM
DougThePilot
Nov 3, 2011 04:49 PM
danielharr79
Mar 25, 2005 08:25 PM
