PCM Shot?
Old Nov 5, 2021 | 06:20 PM
Skidmore's Avatar
Skidmore
PCM Shot?
PCM Fault 1 shows up when I hook my scanner up to my truck. It wont set the I/M readiness. Live data shows the o2 heaters going on and off. But the live data also shows o2 sensors ok. WTF
Old Nov 6, 2021 | 04:28 AM
JWA's Avatar
JWA
You might want to share WTH you're working on??
Old Nov 6, 2021 | 03:56 PM
Skidmore's Avatar
Skidmore
Sorry about that. LOL My bad. Just looking to get my new truck inspected. Wont pass now because the o2 sensors are not being tested by the PCM. I have a 2002 F250 XLT with a 5.4
Old Nov 6, 2021 | 04:20 PM
f31951truck's Avatar
f31951truck
Do you have the code? If you just got a new battery or the battery went dead you will have to drive it for awhile to get the monitors ready. Probably not the PCM.
Old Nov 6, 2021 | 05:49 PM
Skidmore's Avatar
Skidmore
No code. No battery change. But it says Fault 1. Ill get you all more info as soon as i figure out how to post pics. Ill show you what the code reader is showing.
Old Nov 6, 2021 | 06:44 PM
projectSHO89's Avatar
projectSHO89
Better go look at the emissions sticker under the hood to see if you have a California or a "Federal" emissions system.
You're likely wasting your time trying to get non-existent sensors to come to ready. Lot's of threads on this issue (in the appropriate sub-forums...).
Old Nov 7, 2021 | 12:34 PM
Skidmore's Avatar
Skidmore
Its federal. Live data is showing o2s working.
Old Nov 7, 2021 | 02:08 PM
projectSHO89
Which specific I/M monitor is "Not ready"?
Sparce information leads to "20 questions" which causes a lot of knowledgeable guys to simply ignore you. You're already on that border due to the vagueness you've presented....
Old Nov 7, 2021 | 05:24 PM
Skidmore's Avatar
Skidmore
O2 sensor and O2 sensor heater incomplete. I did notice Case Ground on the live feed go from .008 to .018v.
Old Nov 7, 2021 | 08:42 PM
Skidmore's Avatar
Skidmore
OK I dont believe it but I missed something big. Somewhat embarrassing but the downstream sensor is gone! The exhaust was replaced from the cat back and it looks like they cut just before the o2 bung so they can ad exhaust pipe from there. Right now I am going bat**** crazy trying to find the plug that lead to the downstream sensor. I can always weld a bung in and get the downstream sensor setup like stock. looked all over the internet but cant find any info on the location of the connector. Can someone please give me a clue as to where the connector should be?
Thank You
Chris
Old Nov 8, 2021 | 05:15 AM
projectSHO89
Go back and re-read post #5. "Federal" emissions vehicles don't have downstream sensors. Go look in the Super Duty and Excursion forums, this isn't an engine-specific issue.
Old Nov 8, 2021 | 08:59 AM
f31951truck
Project sho89 is right. If it's federal emissions it doesn't have the downstream sensor. Pcm fault 1 means nothing. You must have a code in there somewhere. Maybe try a different scanner or go to one of the chain stores and have them scan it for you. The monitors don't get ready because the PCM is seeing something it doesn't like. Watching data and saying they are working means nothing. O2 sensors can set lots of different codes and appear to be working. Find the code and it will be easy from there.
Old Nov 8, 2021 | 11:05 AM
f31951truck
Old Nov 8, 2021 | 11:12 AM
Skidmore's Avatar
Skidmore
Thanks everyone. Ill check it out.
Old Nov 11, 2021 | 12:07 PM
Skidmore's Avatar
Skidmore
Passed inspection as is. Thanks for the info. I really bugged out when I saw no downstream sensor but as you all new no downstream on the federal.
zcpro
Mar 8, 2014 06:02 PM
290
Aug 13, 2011 02:42 PM
dgpach
Modular V8 (4.6L, 5.4L)
Mar 2, 2010 07:04 PM
kilroy076
1983 - 2012 Ranger & B-Series
Sep 21, 2009 05:36 PM
Roushians
General Automotive Discussion
Dec 24, 2005 10:37 PM
