D50 spindle help
Old Nov 3, 2021 | 04:29 PM
Freakyfran3's Avatar
Freakyfran3
D50 spindle help
1995 f250 d50 ttb Truck fell off the jack stands while replacing the axelpivot bushings. Now the driver side axel won’t spin. After tearing into it, I have no clue what is causing the issue. Looks like maybe the u joint is binding, but when I took the axel out the u joint is moving freely. I have the 3rd member out, so I’ve decided to rebuild everything from the axel seals out. Including hubs and rotors, however I’m having a hard time finding a part number for the outer wheel bearings. And the passenger side axel u joints. If some one could drop some part numbers it would be much appreciated.
Old Nov 3, 2021 | 06:18 PM
JJF20's Avatar
JJF20
First Off, Glad you're here to tell the tale...
I am just doing the same job right now. I bought all my bearings etc through Torque King. If you go to their site and follow the links, all the parts are there, including parts breakdowns if you don't have a manual. I've been dealing with them for a couple years now, always great service in my experience and willing to talk / help you through something on the phone too.
Here's a link for them. Good luck with it.
https://torqueking.com/category/1980...fs-front-axle/
Old Nov 4, 2021 | 10:45 AM
thechief66's Avatar
thechief66
If you post your VIN or axle # I can find the part numbers for you.
Old Nov 4, 2021 | 01:36 PM
obsxl's Avatar
obsxl
you should be able to find everything you need on rockauto, it’s where I got all the parts for my axle
Squirly
May 17, 2021 10:50 PM
capriceragtop
Feb 27, 2014 10:52 AM
BenS77
Jan 26, 2014 11:17 AM
os2firefox
Oct 4, 2013 06:05 PM
MikeMcCasland
Dec 2, 2009 10:32 PM
