Pros / Cons Help
https://bringatrailer.com/listing/1975-ford-f-100-14/
https://www.lagunaclassiccars.com/ve...1972-ford-f100
Obv price is a big difference, but if you assume price is not issue #1, which is the better truck?
Thanks.
I personally don't like the looks of 73 - 79 trucks that much. I think the 67 - 72's have a much classier look to them inside and out so I would lean more to the 72 because of that but the 75 is a very nice truck.
That's my 2 cents anyway...
At what point does the surface rust underneath become a problem?
Sorry just had too...
From what I can see in the pictures you should be able to treat most of the surface rust with a rust converter and then top coat it with paint or coat it with POR15 and then paint. It didn't look too bad and if it's staying in a dry climate it could be fine for a number of years still untreated. If the sheet metal has deep rust pits (floor pans typically have this problem) then it would need to be treated or even cut out and replaced. Most times the carpet/pad holds moisture that leaked into the cab from weather or if the heater core leaked then causing the floor to rust from the inside out.
72 has rust, has been modified, and "good" condition.
Odd features too, it has power steering, but manual brakes. Older AC interior unit but a newer Sanden AC compressor under the hood (that is mounted 90deg the wrong direction because someone didn't buy the right hoses).
Rust underneath and the inside fenders under the hood. Someone tried to cover it up, but made it worse (driver side firewall to fender has poor overspray mess)
Windshield Washers don't work. Wrong size battery (that is backwards). Cool rear sway bar but that doesn't look like a Ford 9" rear end.
But hey, we can all sit around and pick at someone else's truck. Just wouldn't trust the dealer who already lied/ignorant on his marketing. Solid $25,000 truck...
