Check Engine Light on
Old Jun 20, 2000 | 03:36 PM
radsickt's Avatar
radsickt
Greeting all,
I recently bought a 1995 F-150 4x4 with the 5.8l engine. While towing a 4000 lb trailer from CA to CO, I noticed that my "Check Engine" Light would come on occasionally while going up a hill. Sometimes it would turn off going down, sometimes it would stay on until I turned the engine off. Once I turned the engine off and on again, it would go away. It has happened once since then while not towing a trailer. Otherwise, no light. Any thoughts on what this could be? Is this something I can check on the computer box (blinking lights, codes, etc) even though the problem is intermitent? If so, where is the computer box? What are the recommended guides/repair manuals? Thanks for any help you might have -- I am new to Ford Trucks.
-Tim
Old Jun 21, 2000 | 09:15 AM
n5mj's Avatar
n5mj
You'll want to do a KOEO (key on engine off) test to pull the stored code. That will give you an idea what the computer didn't like.
The procedure is in any Chilton's or Haynes manual, as well as a code chart.
Old Jun 21, 2000 | 02:41 PM
radsickt's Avatar
radsickt
Thanks for the note. I just bought a Chilton's manual and will do the check tonight. One thing I didn't explicitly find is where the output socket is... where I need to plug in the jumper wire and such. If someone can drop me a quick note telling me where it is, I'd appreciate it.
Thanks, Tim
Old Jun 21, 2000 | 09:12 PM
danny_1's Avatar
danny_1
aaronbrace
Feb 3, 2023 10:18 AM
1991redneckf150
1983 - 2012 Ranger & B-Series
Jul 5, 2007 03:59 PM
stlmo2
Modular V8 (4.6L, 5.4L)
Nov 19, 2005 04:13 PM
tcasica
Jun 28, 2002 10:00 PM
